993 head studs loose after rebuild?
Hi There
I did a top end rebuild on my 993. The engine was oil tight at first, but after a very few miles is now weeping oil heavily from the cylinder bases. I was very careful torquing the heads, but is it likely/possible that they need torquing again? I did not replace the studs. Also can the heads be re-torqued with the engine in the car?
I used a Wrightwood racing gasket set and a smear of hylomar blue.
Thanks in advance for any opinions.
Berni
Old 09-14-2012, 06:14 AM
If you are leaking at the base I doubt that loose studs are the issue since there was crush on the base O-ring and low pressure drop across that gasket. Sounds like the gaskets have been compromised. I am not familiar with the paste you applied to the O-rings but suspect that to be suspect since it sounds as though you have had multiple seal failures. Most literature I have seen suggests installing those O-rings dry or with Curill.
Old 09-14-2012, 06:24 AM
E Sully's Avatar
What torque did you use originaly on the head studs?
Ed
1973.5 T
Old 09-14-2012, 12:55 PM
Straight shooter
Lapkritis's Avatar
The head studs on these aren't torque to yield/stretch?
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 09-14-2012, 03:16 PM
