WTB ..3.2 main bearings 25mm
I need some main bearings @ .25mm over for mymy 911 with3 a 3.2
Im hoping that someone has them sitting on a shelf in the garage collecting dust..........
my burthday is on the 9th of this month and finding those bearings at a reasonable price would be a great gift.........also seeing this car sitiing in the garage when i should be driving it is bumming me out..............
Old 07-02-2012, 12:26 PM
j911brick's Avatar
Have you tried to order them from Porsche? I doubt anybody has them on the shelf because line boring 3.2 cases is not real common.
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 07-03-2012, 08:52 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Aline bore or undersized crank?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-03-2012, 09:17 AM
Im sure i can get the bearings from germany but im not willing to spend $1200 for bearings. To me thats a little ok alot crazy.
Old 09-09-2012, 08:07 AM
I may have them, let me. Check. They would also be the same for a 3.3 turbo.
Old 09-09-2012, 08:44 AM
j911brick's Avatar
What other choice do you have?
james
Old 09-09-2012, 11:53 AM
One can have the case parting lines machined and the main saddles bored back to standard, however that cost exceeds $ 1200.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-09-2012, 12:34 PM
Bearings
Sorry
What I have are rod bearings .5 mm for a 3.3 turbo
Old 09-09-2012, 09:06 PM
Fyi......its 25mm on the crank.....................so alingn boring not necessary.............also i see him that i have a cracked cylinder. This means ill need at least 3 mahle 95mm pistons/cylinders.
Old 09-11-2012, 12:12 AM
Well thats good because i also need rod bearings that happen to be. 50mm. How much do you want for them? Also did you see my latest post. It mentioned that ill need some used mahle pistons 95mm 3.2
Old 09-11-2012, 12:15 AM
Bearings
You may find it cheaper to buy a STD. crank if you need both rod/mains for your project
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 09-11-2012, 08:18 AM
Your correct in some cases. If i were to purchase the main and rod bearings from germany just the mains would exceed $1200 + about the same for the rod bearings. Ive seen std cranks listed for $1000 ............
However im depending on the good hearted nature of pelican forums users in hopes of finding what i need at a fraction of the cost.
Old 09-12-2012, 11:01 PM
How much??
Old 09-12-2012, 11:08 PM
j911brick's Avatar
I'm assuming you have one bad journal and you need to have the crank ground. Your better off having the one journal fixed or buying a new crank. There is a reason nobody grinds these cranks.
james
Old 09-13-2012, 07:23 AM
#147 of 2096
Hi, I do not have all details but I know that you can use bearings from a toyota tacoma.
Old 09-15-2012, 05:52 PM
