flywheel convertion 911t 69?
among a lot of other issues, my flywheel is in bad shape, starter seems not to have fully engaged a few times and now some teeth are half ground of.
In their wisdom, Porsche made this one part, the flywheel and the ring gear. Has somebody converted the 65-69 flywheel to the newer style ring gear 70-? are they the same diameter to start with? And might it be worth? Will a 70 ring gear + flywheel also work on a 69T engine? Thanks Bernd |
Bernd, the 70-71 requires use of the 911 (as opposed to 901) gearbox. It is also 225mm.
The cup-type 215mm flywheel is your best bet, these are still available new.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
You might check this out on the ForSale section under this header
Bruce Pre 70 clutch package and flywheel |
I have a few early 901 flywheels with good ring gear teeth
PM me if interested.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
