Smart quod bastardus
fredmeister's Avatar
retorqunig cylinder heads after 1000 miles NECESSARY?
I wanted to know if it were really necessary to retorque the cylinder head studs after running the engine for 1000 miles or so?
Considering the magnitude of what it takes to get to the cylinder head nuts with the engine in the car to retorque them, is this something that can be skipped or am I making a terrible mistake?
I have a '79 3.4 liter turbo and am using 98mm Nickies and ARP studs. I am doing a top end rebuild (detonated a piston or 2) and noticed some witness marks on my heads and top surfaces of the liners indicating a little movement after 4000 miles of running.
I did not retorque these after the original engine break in, but dont know if the detonation is to blame for the witness marks or by me skipping the retorque process.
Also, is it possible to get to the cylinder head nuts, say with a partial engine drop, so that I dont go thru an entire engine drop just to retorque the nuts?
Thanks,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-26-2012, 07:00 AM
Air Medal or two
afterburn 549's Avatar
Most will say no.........
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 10-27-2012, 06:01 AM
Originally Posted by fredmeister View Post
...am using 98mm Nickies and ARP studs.
I imagine Charles at LN has some insight; have you contacted them?
'90C4
Old 10-27-2012, 09:06 AM
BURN-BROS's Avatar
I would verify the torque when it's time to adjust valves.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 10-27-2012, 10:01 AM
Thanks,
Fred
Hi Fred,
JMHO,....
You need to stay on top of head torque using ARP studs in a Turbo motor. While they are plenty strong, I've found that the head nuts do not maintain torque settings and loosen up due to differential expansion rates between the studs & cylinders.
We do not use ARP head studs in any engine for this reason and instead, prefer the factory 993TT ones as used in the RSR & GT-2 race engines.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-27-2012, 11:00 AM
