'83 Euro Intake Port Size
There is some conflicting information out there, can anyone point me to a definitive source regarding the intake port size (large or small) for an '83 Euro motor ?
All the euro or ROW are large port. Small port was for the US Lambda system cars.
Bruce |
Intake ports are 39 mm for a large port SC
Tom Butler 1973 RSR Clone 1970 911E 914-6 GT Recreation in Process |
Puny Bird
So if you have one damaged '79 head any ROW SC head would do as a replacement?
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Yes that is correct. The early big port SC heads will have the air injector hole in the exhaust port that will need to be plugged. If you are using the air injection on an early SC, the late ROW big port heads would need to be drilled and tapped for the air injector.
Hmm, my '82 SC 930/16 has air injection heads.
1982 911SC ROW, in Southern France |
