-   -   Any Use For Complete 2.7? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/709226-any-use-complete-2-7-a.html)
Lindy 10-01-2012 06:48 AM
May have finally located an early car for a hot rod project.
Also happen to have a spare 2.7 complete engine that came with another track car. Does the 2.7 (or parts from it) have any value whatsoever as the basis for a carbed street engine, i.e. can the crank, p/c's, heads be used in conjunction with a later 3.0 or 3.2 case??
I realize that there are some very strong 2.7's out there, however if I ever decide to sell the car I am a little concerned with the perceptions that potential buyers could have with a 2.7 engine.
Thanks!
Lindy
Lindy 10-02-2012 06:10 AM
2.7
Based upon the somewhat minimal responses (0), unless someone chimes in I guess this is a good enough reason tof orget the 2.7 as a source of useable parts and build that "big block" I've been wanting to do!
304065 10-02-2012 07:05 AM
2,7 and 3,0 and later cases are different (unless 3,0 Carrera).
Lapkritis 10-02-2012 09:49 AM
If you have a good one then save it as backup... if it is numbers matching then I wouldn't separate from the chassis even if it rolls on a cart as a spare when you sell the car.
