fastfredracing's Avatar
Distributor shaft end play. anyone know the spec?
I am nearly done with my 3.0 turbo build. My distributor, is pretty much the last thing on my list, I have left no stones unturned. I have it dissassembled, and a new shim kit on the bench ready to go. I have measured .085 of end play, and although I cannot find a spec, I am sure that this is just too much.
I DID use the search feature, ,and found mention of .005, and in another thread , a max of .010. Anyone know the definative answer??
No left turn un stoned
Old 10-14-2012, 08:14 AM
I would say that 0.004" would be ideal but 0.005" would be OK.
If you can feel the axial float by hand it is a bit on the excessive side.
0.010" may just about be OK but I would call this the limit
0.085 is too much and almost certainly an issue with a dizzy with contact breakers and a centrifugal advance.
Cast Iron Dizzy with end float adjustment
If you dismantle, it is worth checking out the Vac Advance Can as these are commonly siezed up and inoperable.
Old 10-14-2012, 08:46 AM
