exhaust oil leak
Hi
I have a 1972 porsche 911s targa. The problem is when I start it up oil is coming out of the exhaust!! I am hoping that you may have some idea what is causing this.
Geobed
Old 03-20-2006, 01:08 PM
What do you mean "coming out the exhaust"? It may not be oil, but gasoline coming out the exhaust from being very rich at start-up.
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 03-21-2006, 11:59 AM
Thanks for replying.
It is certainly oil. One mechanic said it may have something to do with the mechanical injection! I was hoping someone would have come across this problem, before we start stripping down the engine.
Old 03-21-2006, 04:02 PM
id911T's Avatar
I've seen engines with exhaust valve guides so worn that they spit oil from the tailpipe during operation. But if that was the case, I would think that you would have a whole host of other problems as well, not to mention smoke.
Stephen
GruppeB #906
1970 911T
Old 03-21-2006, 04:49 PM
It is not the guides as there is no smoke. Very perplexing
Old 03-24-2006, 09:50 AM
Try not, Do or Do not
Henry Schmidt's Avatar
I agree with mtelliott. It is not uncommon for an MFI engine to run extremely rich on start up. With the thermostat, cold start injector and overall rich running of the MFI system you get raw gas running through the engine and out the exhaust port. As it run past the exhaust valve and out the port it washes the carbon off and as it leaks out it looks like oil.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 03-24-2006, 11:13 PM
I talked to my mechanic and he said he drained about a gallon of oil out of the crankcase! If the oil is supposed to be pumped back into the oil tank, could it be the oil pump not working?
Old 04-09-2006, 09:42 AM
How much oil was installed in the oil system? Beginning to read like it was an overfill.
Old 04-09-2006, 09:47 AM
That I don't know. What we can do is drain all the oil out of the system and start from scratch. I guess with a boxer style engine there could be a possibility of oil getting into the cylinders.
Old 04-10-2006, 12:28 PM
The mechanic drained all the oil out and refilled the tank to the correct level. That solved the problem. Thanks for all the help.
Old 05-01-2006, 01:56 PM
Banned
Send a message via ICQ to Marnereox
men gucci belt #9476
Thanks for sharing this, its great
__________________________________________________ __________________________________________________ ______________
designer handbags cheap
cheap replica handbags
Old 10-22-2012, 05:28 PM
Banned
gucci purfume #948
I always like this is type of article. Thank you.
replica purses
Old 10-22-2012, 05:29 PM
Banned
gucci 2010 #5144
great topic, I am interesting in it!
gucci wallet sale
gucci outlet
Old 10-22-2012, 05:30 PM
Banned
gucci gold perfume #8693
WOW!!! Nice topic!Kind Regards
gucci handbags
replica designer handbags
Old 10-22-2012, 05:31 PM
