Which piston rings
Not sure which rings to get for my 911sc. It's a 204bhp european model, late 1980.
My local supplier has two options, 1974-1980 93010396300/1 1981-1989 93010398600/1 So that would probably put me with the first rings. Pelican suggest 1974-1979 93010396300/1 1980-1983 93010398600/1 Which would suggest the second rings. Any way of me telling before I order ? Thanks |
Do a search, there should be plenty of information, then ask the question.
There is a post 2 down from yours where Steve Weiner (reputable engine builder) recommends Goetz brand rings. You should probably buy them as a set unless you have some special requirements.
"Simplicity is supreme excellence" - James Watt |
the ring spec is in mm, measure them so you know. Pistons will be Mahle and inside the pistons there is a discription 2 numbers, a letter and 2 numbers. The numbers are a discription of the piston. PP would know the rings for the piston.
Bruce |
Thanks, did try some searching, but couldn't find which ones I need.
The two numbers are for Goetz rings as they seem to be the ones to go for. Just had a look and the numbers in the Mahle pistons are 95L70 ++ C021 |
You have the pistons out so all you need to do is measure the oil control ring thickness:
930 103 963 00=4.0mm oil control 930 103 986 00=3.5mm oil control The top rings are the same in both ring sets. I would be willing to bet you need the later part number with the thinner oil control ring.
Don Weaver-EBS Racing don@ebsracing.com 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine |
