-   -   High Performance Piston Rings (http://forums.pelicanparts.com/911-engine-rebuilding-forum/713861-high-performance-piston-rings.html)
ale 911 10-29-2012 08:32 AM
I am looking for piston rings that are better than the Goetze. I was looking at the Total Seal, but are there any other brand that make this high performance piston rings?
Steve@Rennsport 10-29-2012 09:00 AM
While I cannot tell you what to use, I would advise you to consider which cylinders you have since some rings since they are not all compatible with the various ring offerings out there.
ale 911 10-29-2012 09:06 AM
My bad I didn't tell which cylinders I have. These are for a 3.3L Turbo with stock cylinders.
Steve@Rennsport 11-02-2012 05:00 PM
I'd be using Goetze rings unless this is a race engine at high boost.
ale 911 11-18-2012 04:31 PM
Sorry for the late response. I've been out for a while.
I am running 1 bar at boost possibly going to run a little bit more. Is it ok to use the Goetze?
Steve@Rennsport 11-18-2012 10:55 PM
One would need a lot more detailed information to offer anything constructive.
What octane fuel in use?
Twin-plug or single ignition?
Exactly how much max boost?
CIS or Engine Management?
ale 911 11-19-2012 08:56 AM
I am currently doing the EFI conversion.
Single plug
93 octane
Right now I have the 1 bar spring, looking forward to be around 16 to 18 psi in some time.
Steve@Rennsport 11-19-2012 04:08 PM
Single plug
93 octane
I will tell you that 93 octane isn't sufficient for 16-18 psi no matter what rings you have. Without 100+ octane gas, its a recipe for new pistons & cylinders.
Our 935's ran 1.3 bar (18 psi), however we had factory racing head studs, sealing rings, twin-ignition and 110-112 octane fuel.
ale 911 11-19-2012 07:52 PM
Ok! Just got cleared up. Thanks :)
