LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
ale 911's Avatar
High Performance Piston Rings
I am looking for piston rings that are better than the Goetze. I was looking at the Total Seal, but are there any other brand that make this high performance piston rings?
Old 10-29-2012, 08:32 AM
While I cannot tell you what to use, I would advise you to consider which cylinders you have since some rings since they are not all compatible with the various ring offerings out there.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-29-2012, 09:00 AM
ale 911's Avatar
My bad I didn't tell which cylinders I have. These are for a 3.3L Turbo with stock cylinders.
Old 10-29-2012, 09:06 AM
I'd be using Goetze rings unless this is a race engine at high boost.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-02-2012, 05:00 PM
ale 911's Avatar
Sorry for the late response. I've been out for a while.
I am running 1 bar at boost possibly going to run a little bit more. Is it ok to use the Goetze?
Old 11-18-2012, 04:31 PM
One would need a lot more detailed information to offer anything constructive.
What octane fuel in use?
Twin-plug or single ignition?
Exactly how much max boost?
CIS or Engine Management?
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-18-2012, 10:55 PM
ale 911's Avatar
I am currently doing the EFI conversion.
Single plug
93 octane
Right now I have the 1 bar spring, looking forward to be around 16 to 18 psi in some time.
Old 11-19-2012, 08:56 AM
Single plug
93 octane
I will tell you that 93 octane isn't sufficient for 16-18 psi no matter what rings you have. Without 100+ octane gas, its a recipe for new pistons & cylinders.
Our 935's ran 1.3 bar (18 psi), however we had factory racing head studs, sealing rings, twin-ignition and 110-112 octane fuel.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-19-2012, 04:08 PM
ale 911's Avatar
Ok! Just got cleared up. Thanks
Old 11-19-2012, 07:52 PM
