Green993's Avatar
What is this?
I am doing a top end rebuild on my 1995 993 c2. While cleaning the case I noticed this black spot in cylinder number three. Top of the pic is top of the engine. Oil breather is on left top. Anyone know what this is Should it look like this or not?
Old 11-05-2012, 09:23 AM
Thats the pressed in oil line and if you look on the outside of the case there is a dimple there too.
Bruce
Old 11-05-2012, 10:45 AM
Green993's Avatar
So you are saying that should look like that? The dark spot?
Old 11-05-2012, 11:06 AM
Spot
It is normal, it is an oil passage that is cast into the case during mfg.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 11-05-2012, 12:13 PM
Green993's Avatar
Thanks guys. It just looked a little strange in that the case was oil colored and this spot was black. Thanks for the help!
Old 11-05-2012, 02:17 PM
