Porsche Crest 3.3 piston ring change. hopefully.
Hi guys.
Just wanted to show some progress pics and maby ask some questions if you don`t mind. I`m hoping to just go in and change #3 piston rings and patch it up again.
Engine out.
How much of a stripdown will i have to do to get access to the sylinder? i want to mess as little as possible
Oheggem
Old 06-03-2012, 12:45 PM
I just did this recently. You can remove the heads, cam towers, cams and chain housings as a single unit. You'll need to remove the chain tensioner stud on the left chain housing to allow the chain to exit the chain housing. It was easy except the unit is heavy. Doing this saved me alot of work by not having to remove all the rocker shafts and cleaning/sealing the cam towers to the heads.
-Andy
Old 06-03-2012, 02:55 PM
was hoping for something like that. Thanks for that tip dude. Will defenatly go for that. Don`t have to split the tranny/engine or strip the top of the engine down?
Just hope i get this back together because the nearest Porsche mechanic is about 600 km away
I`ll give an update on the progress
Old 06-04-2012, 04:15 AM
I think you'll have to remove the intake system and the fan shroud, don't see any way around that.
-Andy
Old 06-04-2012, 02:53 PM
Well i think i fubared up a bit. I forgot to set the cams/crank to TDC. can i fix this after reassembly?
Also i found a locking clip like below:
Found this just below the highest pin here. Can`t remember what it`s called.
I feel like this is never gonna be in one peice again. I feel like this is too big a task! I so hope i can do it!
Old 06-05-2012, 02:24 PM
Alan L's Avatar
Not sure what that clip is off - it is external to the engine tho - must be off some linkage bit or similar. have a good look around before installing - while you can get to everything.
If you are pulling a cylinder you will ave to pull all the cam gear and that head at least, which will mean really pulling the shroud/CIS stuff off. It is not a biggie since engine out - a few simple bolts/nuts. Trying to do less is not worth it.
You can cam time it anytime - but preferably with engine out. If you have put engine back in, you can still do it, but it is 5 x harder. You need to pull the cam chain case off (only doing one side -right?). This means pulling the rear engine tin off. You will need the I/C and manifold off to get at the LHS inlets for the timing. Then need to mount a dial gauge as best you can on the inlet side - preferably #1. You may need to make up a steel plate that will bolt down on the inlet side to mount a magnetic base too - mounting the dial gauge in here is a bit tricky/tight. You don't need to use #1 if it is easier to use #2 or 3.
Not sure if you actually doing this in engine or not, so will post more details if you need them.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 06-05-2012, 04:38 PM
look like the accelerator linkage clips on the throttle body.
Bruce
Old 06-05-2012, 06:03 PM
I`ll be at work for most of the 2 upcoming weeks so no work done but will just continue taking apart the left head and change those piston rings, then do the camtiming later.
Alan, the engine is out and the CIS and stuff is off along with the fan cover Can you not see the pictures? hmm
Thx so far guys
Old 06-06-2012, 02:41 AM
totle's Avatar
Think Bruce is correct in the clip.
It will work out great.
Regarding TDC, no problem. You need to time the cams anyway.
OHeggem, du kan ringe meg, 90884590, om du trenger litt hjelp.
Overhalt noen av disse motorene
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 06-07-2012, 03:11 PM
I thought i`d order the P202 claw thingy for the cam gear when i realized that i don`t have the same as seen with others. I have one nut and nowhere to mount that tool as it mounts off a big bolt head. I thought i`d just airgun it off. Torquing it back on might be an issue as i can`lock it off.
I`m taking the head of without touching the rockers and valves so i don`t have to do valve clearance and stuff like that. I can just throw the head back on, time the cams and be on my way. I need to modify the dizzy though.
Is there any tools i absolutely haveto buy? I will order them at once if there is. have have none of the porsche tools now.
Also ordered the MSD 6424 with a new coil. Will be exiting to say the least.
At work so nothing happens for about a week and a half.
Totle, lagra nr ditt. Forvent en telefon Takker!!
Old 06-09-2012, 01:50 PM
Alan L's Avatar
You'd better show us a pic of your cam end. You can't just rattle gun the bolt back on - or I certainly wouldn't try. Not sure why your cam end would be different.
And I would be resetting the valve clearances while I had the engine out -easier than when the engine is in.
Alan
Old 06-09-2012, 11:39 PM
Pics of the cam end:
Used air pressure gun to get it off. Worked fine but torquing it might be a hassle.
All i had time to do really today because of work
OHeggem
Old 06-10-2012, 11:09 AM
totle's Avatar
When assemble again you Can fasten the pressure plate side and torque according to spec
Trond R.
1986 944 Turbo
Old 06-10-2012, 12:44 PM
Alan L's Avatar
I'm not sure what is different about your cam end. You have a bolt into the cam and a retaining washer. You need to torque the bolt to 88 ft lb.
The difficulty with doing it via the flywheel/crank is that you are putting all the torque load thru the timing chains. Not a good idea really. Best to lock the cam as per original plan.
The other thing you could do is check the timing on the other side first, then synchronise the 1-3 side. While there is a range/tolerance, you want to get both sides the same, ideally. This means checking/setting valve clearnces on 1&4 , so you may as well do the others at same time.
Alan
Old 06-10-2012, 01:57 PM
Well, the difference is that there`s nowhere to use the special tool at torquing the bolt. I will just have to use the crank to hold back. Can`t wait to get the head off.
I will need a special tool to check valve clearance yes? I might just hope to avoid this. Will update when things happen again
Totle, is that where there oil pump to the turbo is mounted? That might work actually! Thx
Old 06-11-2012, 12:37 PM
Alan L's Avatar
You just need 4 thou or 0.1 mm shim for checking the valve.
Your bolt is no different to anyone elses. The tool is designed to work around it specifically to do that job.
At a guess if you use the chain tension to torque the bolt you are applying about 10X the stress the chain was designed to work at. You could verify that once you pull the heads off. It looks like you are going to pull the heads with cam box intact. In which case you can put the lot on your bench and measure the torque it takes to rotate the cam against the valves. My guess would be 5-10 ft/lb. You want to apply 88 ft lb to the chain that drives your engine.
You can imagine the stress on the links, and the possibility of stretching one side of your chain, while the other side is not stretched.
You may get away with it. Others may have done so. All I am saying is it is not good practise and these engines deserve the utmost respect when working on them - ie best practise , if you don't want issues after.
The oil pump is the turbo scavenge pump and drives off the end of that cam - by a drive pin. Not sure if you can lock the cam from there (can't think of how you would do it). I think he was referring to locking the flywheel.
Alan
Old 06-11-2012, 02:22 PM
totle's Avatar
As Alan said, I was referring to locking the flywheel, not the cam at the scavenge pump side.
Oheggem, Give me a call and I will explain the procedure for piston to valve clearance
Trond R.
1986 944 Turbo
Old 06-12-2012, 12:10 PM
Oheggem , I am traveling now but will be back in Norway on the weekend. I have the correct cam holding tool, you could borrow it for the short time you need it to time cams. If you dont have Waynes book, it is very helpful. Also search this forum for "cam timing" and spend an evening reading posts
Ring meg lordag 92021588
Regards,
Wade
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 06-13-2012, 08:34 AM
Been super busy at work but removed the head today. Also the sylinder to check those piston rings. They are intact but the gaps where right next to eachother. On the picture i had moved the top ring a bit.
http://postimage.org/image/lrsnhlovt/
Can that cause smoking? What`s next to check?
Old 11-11-2012, 10:35 AM
The piston doesnt look like it has a problem with blow by the rings.
Bruce
Old 11-11-2012, 06:27 PM
