I found these cams I picked up years ago...
...while looking for something else. I am intrigued why they are MFI. They are stamped as Elgin 304 288, but the date stamp on the cams '68 makes them earlier than MFI? Also, the casting number appear to be from different years.
![]() ![]() Elgin stamps ![]() ![]() Dates ![]() The box confirms ![]() Can someone explain why these were 69 billets, but ground for MFI and where the grind sits with a comparable 69 -73 S cam. Thanks Speedo Last edited by speedo; 11-24-2012 at 05:30 PM.. Reason: wrong pics |
911 143 and 144 are billets for CIS S for the 2.7.
You can call Elgin and they can tell you what they are for with their regrind. MFI cams would have a drive on left cam. Bruce |
Woops wrong pics of the cams...
I re-posted the correct pics. The left side cam definitely has the MFI drive....I just don't have the pic showing the drive. Let us start all over from the beginning.
Speedo |
up-fixing der car(ma)
911S part numbers, and late '68 dates...'69S which had MFI
Reground a little hotter to "304/288". S should be around 300/270 according to Elgin's website. That is probably a pretty good cam, probably basically like a Mod S cam. You could try Elgin and see if he knows what it is. After horrible experience with John Dougherty, I recently worked with Web Cam to figure out an unknown set of cams I had. They did a great job and were fast & professional. They can tell you exactly what you have there. No personal experience with Elgin.
Scott Kinder kindersport @ gmail.com |
Guys...thanks
That was exactly what I needed. Go have a turkey sandwich
While I am asking questions...another strange set
These are supposed to be T cams for a 69, but they shouldn't have the MFI drive. My thought was that they were 72-73 T cams but the numbers don't jive.
![]() ![]() ![]() TIA Speedo |
Lars
That last pair are the T MFI cams 1972/73.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
The 6976 should reference the original invoice number if you call Elgin
John Dougherty Dougherty Racing Cams |
I have a set of these cams too. Any idea where to set the cam timing. I will be using them in a 2.5 long stroke
Hey speedo (Lars), sorry about your thread but,
John - you haven't replied to my phone calls, emails and won't return what was agreed upon so perhaps this is the only place you read? Where is my 906 cam and the $$ you owe me ?? Quote:
