3.2 upgrade ??
I want to add more HP to my 84 3.2l I allready have a "20hp" chip on the ecu, headers and air intake any othe think I can do to my set???
In adition I need some recommendation ...
open the engine to put 3.4l piston set or add a turbo to 4 to 5 pounds?
what the best option for power, efficiency and economics???
Old 01-13-2013, 10:50 AM
Here are some things that pay nice dividends:
1) 3.4 conversion
2) Twin-ignition
3) 964 cams
4) Extrude-hone intake manifolds
Nothing here that compromises engine longevity like forced-induction does,..
There is a LOT more to do that includes a different intake system, however that will severely dent your wallet.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-13-2013, 11:47 AM
3.4 conversion what I need??
Old 01-13-2013, 12:49 PM
flat6pilot's Avatar
Search around a bit on the board. There's probably quite a few 3.2 to 3.4 conversion threads.
Start here for some ideas:
Carrera Rebuild 10.3 Pistons & Cylinders
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 01-13-2013, 01:28 PM
thanks for the info,, and how much HP increase with the
1) 3.4 conversion
2) Twin-ignition
3) 964 cams
Old 01-13-2013, 02:03 PM
AlfonsoR's Avatar
I think you can get some idea here:
911Chips - Porsche Dyno Runs
What kind of power are you looking for? What kind of budget? If you go all out, $25k+, you can get 350 hp or so out of a ~3.5. Not sure what how much hp or $$ for going the turbo route, but some people think this is the most economical way to at least 350hp and beyond.
You may want to look on the Turbo forum for more info there.
"Simplicity is supreme excellence" - James Watt
Old 01-13-2013, 06:22 PM
thanks for the info...
Old 01-14-2013, 11:07 AM
