-   -   Crank fire ignition question? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/728740-crank-fire-ignition-question.html)
crashmy911 01-14-2013 01:30 PM
Looks like toothed wheel is smaller then my old pulley. ENGINE IS 3 liter sc engine and belt looks like it is too long now. trying to tighten up new belt and looks long.
HawgRyder 01-14-2013 03:57 PM
The loose belt may be the least of your problems.
If the pulley is a different size (smaller) then the ratio for the cooling fan will be too small.
The fan will be turning at a lower speed (giving less cooling air).
Bob
KTL 01-15-2013 08:57 AM
The typical pulley sizes that are made with crankfire setups are 116mm and 127mm. SC 3.0L wants a 127mm. If you have the smaller 116mm pulley, then yes your belt will be too big.
