Crank fire ignition question?
Looks like toothed wheel is smaller then my old pulley. ENGINE IS 3 liter sc engine and belt looks like it is too long now. trying to tighten up new belt and looks long.
Old 01-14-2013, 02:30 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
The loose belt may be the least of your problems.
If the pulley is a different size (smaller) then the ratio for the cooling fan will be too small.
The fan will be turning at a lower speed (giving less cooling air).
Bob
Bob Hutson
Old 01-14-2013, 04:57 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The typical pulley sizes that are made with crankfire setups are 116mm and 127mm. SC 3.0L wants a 127mm. If you have the smaller 116mm pulley, then yes your belt will be too big.
Kevin L
'86 Carrera "Larry"
Old 01-15-2013, 09:57 AM
