993 rebuilt top end how long to fix leak?
Hi There
I rebuilt my 993 top end and seem to have oil leaks from the cylinder bases. I must have got the Wrightwood green viton gaskets twisted, or else they did not like the smear of hylomar blue I used.
Assuming I have no other avenue but to drop the engine, what is the absolute minimum of disassembly I will need to undertake the gasket change? Can I get the cylinders heads and cam towers off along with the cams and gear all assembled and then back onto the pistons in one go?
Thanks for any advice!
Berni
Old 02-18-2013, 04:24 AM
