nickd's Avatar
Engine build at the factory
I haven't seen this shared yet. Engine work comes in at 2:23. I don't see much oil on those pistons as they slide them in? Chains are looking pretty dry as well.
1991 964 C4 Cabriolet - drop-top pylon destroyer
Old 05-13-2017, 06:21 AM
War Vet
matt930s's Avatar
Great vid....918 at the end is sick...
MattR
Dr. Phatt
Old 05-13-2017, 07:23 AM
I was just there a month ago and saw that in person on the factory tour. The degree of automation is staggering. Every 2.5 MINUTES - minutes! A new 911 or boxster comes off the line. It takes them less than 3 hours to build a single engine.
Old 05-13-2017, 12:34 PM
Functionista
manbridge 74's Avatar
I know a pro engine builder who uses nothing more than a spritz of WD-40 like lube on pistons. Rings seat way faster....
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-13-2017, 01:03 PM
Puny Bird
Mark Henry's Avatar
More than 25 years building VW and Porsche engines, I've never used oil on the pistons/rings.
Once installed and heads on I put a squirt of oil down the plug hole.
Same with chains, lube them after they're in.
Think about it, lube and sealant becomes a cross contamination nightmare.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-14-2017, 09:09 AM
