It's a trap...
Speed Buggy's Avatar
Location: 1/2 way between the Motor City and the Glass City.
Question Restarting reassembly - what do I need to do?
I have been busy and now need to get back to building up my motor. I have the case together. I had to remove one rod to have the piston bushing resized. Is the assembly lube I put on going to be enough? It has been sitting for about 5 months. The next thing I need to do is put the one rod on and then the cylinders. I had to get one new cylinder and piston. It has the same casting numbers as the existing cylinders. Should I do a deck height measurement? Thank you. Cheers, Mike,
Run like the wind, straining the limits of machine and man....
2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys).
Old 02-02-2013, 11:04 AM
