Banned
Loctite 510, 518, 573 which one should I choice?
HI
I can not find 574 Loctite in my country(574 can not ship over sea unless 10 cans special order from Loctite dealer), but I can find 510, 518 ,573. Which one do you guys recommend for high HP 930 engine? Need you guys input thank! 518 http://www.dekkervacuum.com/pdfs/uploads/Loctite518ProductDataSheet_6_27_2007_10_02_34_AM.p df 510 http://www.industrial-gp.ro/media/21334/510_fisa_tehnica.pdf 573 http://tds.loctite.com/tds5/docs/573-EN.PDF |
So far i know, Porsche used the Loctite 573 in earlier days. I used 574 with success.
Porsche 911 SC 3.0 |
Schleprock
573 has a very long cure time so it will allow you a longer time for assembly of the case thru-bolts, o-rings and perimeter nuts. No change in strength when exposed to motor oil. Least amount of strength loss when exposed to gasoline. It's green.
518 has the fastest cure time which is about 1 hour in our application. It gets stronger with exposure to motor oil. Loses the most strength exposed to gasoline. It's red. 510 is the middle cure time, still long. No change in strength when exposed to motor oil. Falls in between the other two in strength loss when exposed to gasoline. It's pink. Bottom line they'll all work. All are medium strength rating and perform well in terms of strength vs. temperature vs. time. Cure time is OK for all of them, since we all can typically get the case sealed within an hour (518) and the others allow you to take your own sweet time. I'd choose 518 if it were up to me.
Kevin L '86 Carrera "Larry" |
Perhaps someone stateside could send you a tube of 574. Where are you located?
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
