911Shoes's Avatar
Rennline block of plates and blower motor cover installed!
Old 11-28-2013, 12:53 AM
Not Royce
Royze's Avatar
subscribed!
very nice documentation of your progress, please keep us updated.
i like the two tone (tan/black) of your interior & the exterior color as well!
Pistache: 1984 911 backdate
@RWB_Royze on IG www.instagram.com/rwb_royze
RWB Japan/Middle-East representative
Old 11-28-2013, 01:26 PM
Hello,
Cool picture in the site,otherwise every information are good.I will agree to other member,i personally talk about the site with my friend.thanks
Sacramento Airport Shuttle
Old 12-01-2013, 07:28 AM
911Shoes's Avatar
Replaced the Clutch cable. Removed it from where it connects to the front of the tunnel, then pulled it out through the rear. Fed the new one in and reconnected it at the front.
Cleaned out the fuel filler and replaced the fuel filler flap
Replaced the rear deck lid strut with pelicans dual heavy duty strut! These two shocks are easy to install and hold the lid up with no struggle
New fuel pump and fuel lines with correct banjo fitting
New fuel pump and fuel lines installed
New fuel tank Installed from Porsche, reused the Vdo fuel level sending unit, Rust clean up will follow on front battery tray
Painted the rear engine compartment
Old 12-19-2013, 08:54 PM
You need 17 to 20 turns on the clutch cable into the clevix in order to be able to adjust the clutch without running out of threads in the rear.
Bruce
Old 12-20-2013, 03:08 AM
2.7 rebuild specifics
Nice thread. Thanks for posting. curious about the 2.7 rebuild you are going to do. You could add 9.5 JEs,40 mm carbs, E cams, SSI 2 in I out muff. but would that give you the 230 hp you requested? Wouldn't that be 200 to 210? best
Old 12-20-2013, 09:47 AM
Location: NE OH where owning a boat a plane or a convertible makes no sense. I'm 2 for 3
Awesome thread. I just started the rebuild of my 77. Going to go with a 3L engine. Fuel tank is out getting cleaned, that was the first step after collecting the pieces and parts from the seller. Was debating about whether or not to go with the wide body look. Afte seeing yours... Done! It's going to happen!
Old 12-20-2013, 08:12 PM
911Shoes's Avatar
Bruce
I have everything in and fitted. I matched it up pretty good to where it was before. Just waiting to get the engine back then with the transmission in I'll adjust it and sug up the nut to the clevix! I hope I have it pretty close!
I know we are running Pmo carbs, Mahle p&c's, different cams, SSI not to sure what else but it should be pretty close... I hope If not I'll have to add some stickers! They ad hp right
The fuel tank along with the lines and the correct banjo fitting can be quite a task! After scratching your head a few times and taking a break it can all be done!
More updates
Rennline Pedals installed
Oil tank going back in after being cleaned up and repainted from paciffic oil coolers new gasket on the oil level sending unit and new boot for the wire! Ground wire added
New tail lenses installed
New engine+transmission mounts in Oil filter ready to go!
Old 01-01-2014, 11:29 PM
Love the progress! Curious - where did you get the rockers from?
Old 01-21-2014, 08:46 AM
911Shoes's Avatar
They were installed by one of the previous owners! They look like they have been on the car for a long time and it looks like they were installed with coopper
New sunvisors installed from Porsche!
Still waiting on the engine!!!!
Old 01-21-2014, 11:18 PM
911Shoes's Avatar
Fuel lines are going in with the fuel filter and the crank case breather.
Big thanks to Len Cummings at Auto Sport Engineering for making some lines for me from the tunnel lines up! These were direct fit!
Modified oil catch can will be going in next!
Old 02-06-2014, 03:48 PM
911Shoes's Avatar
Installed the Crank case breather after shortening it 2 inches and putting a new hose fitting on it from 1.5 inch to 1 inch to accommodate a 1 inch hose from the oil tank to the breather, Then changing out the drain fitting from a straight to a 90 degree brass fitting for easier routing.
Glued in the door seal and screwed in the felt seal that runs on the top of the door jam
Doors seals nice and snug now
Old 02-20-2014, 10:58 PM
911Shoes's Avatar
replaced the sunroof seals
Old 02-22-2014, 11:27 PM
911Shoes's Avatar
Installed some Recaro sportster seats!
Have the Msd in place!
Battery in the smugglers box!
New key and key head!
Cleaned up the transmission!
Pictures of the engine!
Dyno numbers!
Old 05-15-2014, 11:13 PM
JmuRiz's Avatar
Wow, great numbers. That thing will haul butt...too bad it wasn't a local that did the build, I'd have to talk with them about mine, haha.
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 05-16-2014, 06:31 AM
911Shoes's Avatar
Got the car running on 6/16/14 I've included a link of the car running and some pictures of it out of the storage unit
Link to car running and walk around video!
77 porsche 911 2.7 walk around - YouTube
Engine about to go in
Engine in!
Gas station
Top of Skyline Drive in Virginia
Thank you for all the help and support! Couldn't have done it without the help of so many great people on this website.
Old 08-21-2014, 11:20 PM
JmuRiz's Avatar
Walk-around video looks like a for-sale video...but I don't think that's the case, right>?
'64 356SC
‘19 Audi SQ5
Old 08-22-2014, 07:09 AM
It's on eBay
Old 08-23-2014, 03:18 PM
911Shoes's Avatar
Originally Posted by 77Targa0912 View Post
It's on eBay
I had it listed to see what interest it would build, it's no longer on ebay. However if someone offers the right amount I would let it go to start another.
Old 08-23-2014, 03:59 PM
puddy's Avatar
Very nice car! If I was in the market I'd be all over it. Good luck with sale!
Old 01-11-2015, 01:25 PM
