-   -   ID This Mahle Piston, please. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/733473-id-mahle-piston-please.html)
series9 02-10-2013 01:59 PM
I started tearing down a 911/07 engine today. It should be a 2.2T. It's not.
I find that I have 80mm P/Cs of the Mahle Biral variety.
I believe this to be an E piston, yes?
http://forums.pelicanparts.com/uploa...1360533544.jpg
ajwans 02-10-2013 02:48 PM
Flip it up and look down on the underside of the crown. There should be some cast identifying numbers/letters.
andy
Flat6pac 02-10-2013 03:14 PM
There should be a casting number such as 80wxx or some such. We need that number
Bruce
series9 02-10-2013 03:36 PM
It's difficult to make out. Looks like:
80V79
CO11
E30
series9 02-10-2013 03:40 PM
On the dome:
2
14
M
129
On the inside of the skirt, on the intake side:
45
9
M
series9 02-10-2013 03:44 PM
Bottom picture:
http://forums.pelicanparts.com/uploa...1360539874.jpg
BURN-BROS 02-10-2013 03:46 PM
It looks like a 2.0 liter E piston from 69. It's a cast piston and would have used the biral cylinder
BURN-BROS 02-10-2013 03:50 PM
Are you sure it's not a 901/07? I think that is a 68L .... It would have the same pistons as the 69E and would be a 2 liter
series9 02-10-2013 04:02 PM
It's built from parts. It has T cams, 2.0 T heads with casting dates from '67 to '70 and I think it has a CW crankshaft.http://forums.pelicanparts.com/uploa...1360540962.jpg
Flat6pac 02-10-2013 05:50 PM
I have it listed as a 2.0E, 1969
2.0L has a different casting number and its 9.0CR and the 69E is 9.1CR
Bruce
series9 02-10-2013 06:24 PM
Thanks Bruce.
