964 & 993 Crankcase Identical
Are the crankcases for the 993 and 964 identical? They have the same part no:
964-101-905-10 There seems to be a new, superceded version with an 11 at the end. What is different about this newer on vs. the older one? Thanks! |
The newest cases for 964 are in the 997 turbo and have no openings for the oil return tubes on the side of the case.
Bruce |
993 cases have fewer studs, using bolts instead.
| All times are GMT -8. The time now is 05:34 PM. |
