Smart quod bastardus
fredmeister's Avatar
whats the normal clearance between valve guide and stem for the OEM 930 wastegate?
This is a turbo specific part but thought guys on this forum might know the answer to this question:
What is considered a normal clearance between the valve stem and the valve guide bore for an OEM 930 turbo wastegate?
I can here air blowing past the valve guide and into the exhaust port when I pressure test the wastegate housing. I realize a small amount of air will inevitably pass thru the clearance gap bewtween the 2 parts, but when is it time to replace the valve guide from wear? I have not been able to find a spec on this yet. Would like this info in order to be able to machine a new guide and have it pressed into the housing if need be.
Air leaking past the guide is air lost to opening the wastegate valve so ideally this should be a minimum.
Appreciate any info,
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-14-2013, 11:26 AM
ivanuf's Avatar
Anyone has some answers to this old post?
79 SC Back to Basics!
2006 997 C2s Cabrio - Sold
1999 996 C2 - Sold
Old 04-21-2017, 05:25 PM
I would assume it would be no more that a exhaust valve guide which is .0022 thou
regards
Old 04-21-2017, 07:25 PM
Originally Posted by racing97 View Post
I would assume it would be no more that an exhaust valve guide which is .0022 thou
regards
Exhaust valve guide clearance should never exceed .007".
.022" is FAR too much.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-24-2017, 05:23 PM
.0022 is two thousands and two tenths a little less than .007 aye....
regards
Old 04-25-2017, 11:04 AM
I did a quick search of the forum. Came up with this.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/748196-overboost-problem-solved.html
Old 04-27-2017, 10:18 AM
