Free minder
3.3L turbo cylinders on 3.0L NA
Has anyone ever considered using 97 mm 3.3L cylinders from a turbo motor in a 3.0L engine, making it a 3.3L NA motor? Of course this would require higher compression pistons since orginal CR was 7.5:1, but we already know the cylinders will fit since the cases were the same. Any downside to this idea?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Champagne on Beer Budget
The 3.3 cylinders are only finned on one side...most people convert to fully finned cylinders when rebuilding the 3.3's as they cool better/more evenly.
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
You need the crank and rods to do it.
Cylinders all fit the same hole in the case. The 3.2/3.3 has a different size wrist pin than the 3.0. 95mm cylinders will open to 98 for more cubes. Bruce |
Free minder
Right, I did not realize the stroke was longer on the turbo motor. With 70.4 mm stroke, that only gives 3.12L, not really worth it. But this brings another question: Do the longer rods fit the 3.0L crank directly, or was the crank different too?
