ID this Twin Plug Distributor??? RUF product?
I'm searching for information on this twin plug distributor. This was on a RUF 3.4L BTR 930 Turbo engine. I'm converting the engine to EFI and trying to determine if this is a RUF distributor. Any idea as to a fair market value for this distributor? The cap is chipped and cracked.
img]http://forums.pelicanparts.com/uploads22/DSCF87971387759830.jpg[/img]
Old 12-22-2013, 04:59 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Many companies built conversion plates like these. Most were bolted in place but judging by the weld quality, welding was an after thought.
The conversion plates were valued from $125 to about two hundred.
The end of the distributor was machined down to fit the rotor but because there was no bearing to support the over-sized rotor, these distributors had a short service life.
With the high cost of a replacement cap and rotor it hard to put a value on this part.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 12-23-2013, 05:56 AM
