? Parts That Should Be Reassembled In Original Positions
Trying to figure out which parts I should label/mark to ensure they are reassembled in the original location/position.
For example: I'm sending the heads to a machine shop for Inspect/R&R - is it important to mark the heads #1-6 so can I reassemble and mate to the corresponding #1-6 cylinders that they were attached to when dissassembled. I understand the point of reassembling parts that have friction points (ex. pistons in original cylinders, bearings remaining with same lobes etc.). I don't see where it matters when you are having parts machined though. Another example: rockers - I'm having the cams & rockers reground, Wayne's book recommends replacing the rockers back in original positions (for camshaft housing fitment). What needs to go back in original positions when reassembling - I'm thinking just friction worn mated parts that are not being machined or replaced, am I wrong? Thanks Gordo
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 04-05-2013 at 06:40 AM.. Reason: Grammar |
Puny Bird
If it's machined it shouldn't matter, on the heads if you don't get them flycut then it does matter. I still return the pistons, jugs and heads to the same spot, I use a cheap $10 engraver to mark them. If it hasn't been machined it goes back the same place as it came out.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Scribing
Thanks Mark,
I have a cheap engraver as well - scribed the heads and other parts for installation back in their original location. Don't necessarily see how it matters for quite a few parts since many are new or machined, but I guess once I started scribing, I couldn't stop. Gordo
Don "Gordo" Gordon '83 911SC Targa |
On my 1980, all the heads are numbered by the factory, 1 - 6.
Kinsley 1980 SC Targa - MS2, EDIS |
