Case through bolt O ring lube question
So based on earlier research I ordered Dow Corning Dow 55 for O rings ( per Henry)
I received DuPont Molykote 55… A vendor applied sticker says DowCorning 55. Not what I asked for but is it legitimately equal. Thanks
TOT |
Try not, Do or Do not
What you are seeing is just marketing differences.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Lube
10-4
Thank you
TOT |
