304065's Avatar
Need a crank dimension for 66mm crank for speedi-sleeve install
What is the distance between the end of the crank and the face of the thrust flange?
Trying to determine what tools needed for speedi-sleeve install on end of crank.
Thanks neilca for the photo
Here is the SKF speed-sleeve 99254 that neilca installed and found to be too long to fit over the end of the crank
Looks like the 99254 is 22.99mm long. With the driving ring cut off, the sleeve is 19.99mm long.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 05-06-2013, 09:44 AM
356RS's Avatar
I measure 15.40mm from the flywheel face edge to where the radius starts and 16.25 mm from the flywheel face to the back of #1 thrust.
Mark Jung
Bend, OR
MFI Werks.com
Old 05-06-2013, 11:43 AM
304065's Avatar
Thanks Mark! This is a big help. It means that the Speedi-Sleeve must be cut to fit over the crank, whether the driving ring is installed or not.
This is an off-the-shelf part from SKF, they don't really make it for a Porsche specifically. Hence it is too long out of the box.
link to old thread Install of Speedi sleeve to repair crank
issues:
1. flange is 3mm long. with the seal in the factory location, does the peak of the seal ride on top of the groove? Or further outboard?
2. if you remove the flange, then what? how do you get the sleeve to move 3mm down closer to the thrust flange? You can't heat it, so say the instructions, as it may distort.
3. nor can you drive the sleeve on with a block of wood and a hammer, as it tends to buckle because it's so thin.
4. there must be enough clearance on the end of the crank to allow the flywheel's mating flange to clear. This measures at 4.0 mm.
15.40 - 4mm = 11.4mm width from the curve of the sleeve.
So we end up with needing about a 10mm wide strip of steel on the crank for the seal to ride on.
to shorten the sleeve is going to require a mandrel that is 65mm diameter and a big tubing cutter to make the cut, or a lathe. I don't have a lathe handy.
'81 R65
Old 05-06-2013, 12:25 PM
