SINGLE PLUG 10.5cr 3.0 CIS MOTOR
I WANT TO BUILD A 3.0 ENGINE USING 10.5 cr JE PISTONS AND S CAM AND WEBER 40
CAN I GET AWAY WITH SINGLE PLUGGING THIS ENGINE USING CALIFORNIA 91 GAS?
Old 04-13-2013, 08:23 AM
Straight shooter
Lapkritis's Avatar
El Centro is hot... I wouldn't. 9.5:1 max on single plug would be my recommendation.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 04-13-2013, 08:57 AM
Nossir,....thats a sure-fire recipe for buying new pistons again very soon.
10.5:1 on single ignition requires race gas, especially in warm weather.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-13-2013, 09:13 AM
Wow.! Thanks for the useful info.
Old 04-13-2013, 03:16 PM
