Jitters's Avatar
Send a message via AIM to Jitters
Viton O-Rings
Hi,
I'm currently reassembling my 3.3 turbo due to some pretty bad oil leaks at the cylinder bases. I'm assuming that these were caused by replacing the previous Mahle cylinders with Perfect Bore cylinders which I just realized have a groove at the base of the barrel.
I've read a few threads and have been told by one person that I can use viton o-rings to correct this problem.
Where can I find this type of o-ring and does anyone now what the size would be for my application. I'm currently running 98mm P/Cs...
Best Regards,
Todd
1988 930 Turbo...
Old 10-27-2012, 03:24 PM
A groove on the base of the cylinder is 3.6 base seals replacing the copper of the 88 turbo.
Bruce
Old 10-27-2012, 03:33 PM
Smart quod bastardus
fredmeister's Avatar
Can you reuse the copper base gaskets on the 3.3 liter engines?
sorry to go op topic.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-27-2012, 03:43 PM
Originally Posted by Jitters View Post
Hi,
Best Regards,
Todd
Viton is an elastomer that has high resistance to heat-related degradation and thats all we use when the option is available.
I've not seen the PB 98mm cylinders with O-rings so I cannot tell you anything, however if I had the measurements, I have sources for those things. Every cylinder that I've used has provisions for the normal flat base gaskets so I'd need to see what you have.
Remember, O-rings generally require a matching groove in both sealing surfaces to be effective.
I would not overlook the role of loose heads as you do the forensics here to prevent a recurrence. Many aftermarket headstuds do an inadequate job of holding clamping pressure and that allows the whole assembly to leak.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-27-2012, 04:00 PM
Jitters's Avatar
Hey Steve,
Thanks for the feedback. The barrels actually have grooves on the top and base. I had grooves machined into the top of the barrels to accommodate Ni Resist rings. The grooves in the base of the cylinders were already there; however, the surface that mats up to the base of the barrel is flat. The measurements of the groove looks to be approximately 1/16in x 1/16in.
This was my first engine dis-assembly and when it came time for reassembly, I didn't pay attention to the groove in the base of the barrel. Needless to say, once I finally got the engine back in the car it leaked like a faucet and definitely not drivable at all.
I was actually considering filling the groove with some type of silicon sealant but wasn't sure if it would stand up to the heat of the engine. I'm not that experienced with these things so I thought I'd start asking questions questions in hopes of coming up with viable solution to my problem.
1988 930 Turbo...
Old 10-27-2012, 07:51 PM
Forced Induction Junkie
WERK I's Avatar
Could you show a photo without the base gasket?
Dave
'85 930 Factory Special Wishes Flachbau
Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P
Old 10-29-2012, 07:46 AM
KTL KTL is offline
Schleprock
KTL's Avatar
When a friend discovered his RSR cylinders had upper sealing surfaces with grooves in them, and the diameter was not a common one (meaning, the replacement gaskets are rather expensive), a friend who works in Navistar diesel engine design mentioned that they use a graphite packing material. So that's another consideration.
I'm not saying the Viton solution is not a good choice. Just mentioning other types of sealing used in this sort of application.
Kevin L
'86 Carrera "Larry"
Old 10-29-2012, 08:20 AM
Jitters's Avatar
Hey Kevin,
Thanks for the information. At this point, I'm open to solution that makes sense and that will work...
Best Regards,
Todd
1988 930 Turbo...
Old 10-29-2012, 05:53 PM
Jitters's Avatar
Hey Steve,
Hey Dave, I'll pull one of the Cylinders and take a snapshot and post....
1988 930 Turbo...
Old 10-29-2012, 05:57 PM
Jitters's Avatar
Better snapshot of what I'm referring too...
Dimensions of the space that I need to have filled with some type of o-ring is Groove Height = 1/8in X Groove Width = 3/16in
Would need to have an ID = 4 1/8in
Not sure if this is significant but the surface of the case is flat with no groove, so I'm not sure if that's relevant or not.
1988 930 Turbo...
Old 10-30-2012, 06:26 PM
Jitters's Avatar
Well, looks like I'm not going with the Viton o-ring solution. Talked to Loren Beggs over at 911 Design and he's going to shave the existing barrels and then fabricate a set of aluminum adapters for me....
Thanks to those of you who offered suggestions to my problem.
Best Regards,
Todd
1988 930 Turbo...
Old 11-03-2012, 10:01 PM
WERK I's Avatar
I take it you got these cylinders used from another source. Did you check the deck height with the new cylinders before final assembly?
Dave
Old 11-04-2012, 08:42 AM
Jitters's Avatar
Hey Dave, yes to both. Picked them up from a gentleman over in the UK, who used them once in one of his race cars.
When I received them, I had them professionally checked out by a professional builder and gave me his blessings. Had all measurements done, including cylinder bore measurements as well.
Best Regards,
Todd
1988 930 Turbo...
Old 11-04-2012, 08:56 AM
Jitters's Avatar
Got a hold of the Viton o-rings. The plan is to install with the oem gaskets and not apply any type of sealant.
Is this a recommended strategy or should I use any sealant to make sure there are no leaks?
Best Regards,
Jitters
1988 930 Turbo...
Old 11-16-2012, 05:54 PM
Wer bremst verliert
JohnJL's Avatar
Did you check with Perfect Bore?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 04-28-2013, 08:32 PM
