Wrong PMO Manifolds for 3.2L
Just realized that the used set of PMO carbs that I purchased have the wrong manifold for a 3.2L. When I purchased them, I had no clue about manifold port sizes - I was focused on carb size and configuration...
The manifold that I have is a 46mm top / 36mm bottom configuration. I had seen manifolds listed with 2 numbers but for some reason, it never connected. From top to bottom, here's the layout - 46mm carbs as measured from the base/butterfly opening: 46mm port on the top of the manifold: ![]() 36mm port on the bottom of the manifold ![]() And then opening to the 41mm port at the head ![]() Looks like this manifold set will be headed to the used parts board. Gordo
Don "Gordo" Gordon '83 911SC Targa |
Taper bore them or even get busy with a die grinder and some tungsten bits ? won't take long
Try not, Do or Do not
Before you modify your manifolds, make sure the flange is large enough to cover the injector cutout. If you have the CIS manifold, it may not be big enough.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Manifold Mod
Agree Henry, I doubt these could be opened to 41mm - not that I have any intent to
modify a perfectly good/nearly new manifold. Thanks, Gordo
Sell 'em and get the correct ones from Richard. I'm in the same boat.
Todd
'81 SC |
Manifold Size
I'm trying not to focus on expenses (oops - I bought the wrong manifolds, there's another $400 + $60 for the insulator kit). Just want to make sure I do things right and get the results I want. Paying too much attention to expenses could lead to cutting corners, and loss of my already frail sanity ![]() Gordo
I don't think the 41mm manifolds will be any better at covering your intake port. The CIS insulators are what cover the injection cut-out.
-Andy
72 Carrera RS replica, Spec 911 racer |
PMO Manifolds and Insulators
I think... Gordo
