-   -   3.3SS rebuild finally underway.......... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/747632-3-3ss-rebuild-finally-underway.html)
fred cook 06-14-2013 01:26 AM
Forgot the pics...........
http://forums.pelicanparts.com/uploa...1371198180.jpg
http://forums.pelicanparts.com/uploa...1371198205.jpg
http://forums.pelicanparts.com/uploa...1371198226.jpg
fred cook 06-14-2013 04:14 PM
Day 44, Friday...........
Connected the wiring to the alternator and installed the top shroud. Spent some time locating and adding wiring loom clamps on the harness so that it would occupy as little space as possible. Replaced the ends on a couple of wires going to the senders on the front of the engine because of age/heat damage to the insulation. Added all of the perimeter engine tin, finished fitting the a/c mounting brackets. Temporarily set the a/c compressor in place and measured for a new a/c belt. Lucked out and found one that fits perfectly on the first try! Installed the 6 lower spark plugs and in the process, found a piece of the engine tin that had to be modified slightly to allow the lower #3 plug to be installed. Last of all, spent some time cleaning up the shop and cleaning/putting away tools!
Basically, all that's left is to install the CIS system, get the engine off the stand and add the clutch disc and pressure plate. I hope to at least get the injection installed tomorrow! Getting really close!
fred cook 06-14-2013 08:03 PM
Pics from today's work
The a/c compressor and mount will come off prior to installing the CIS. The a/c compressor also needs a final cleaning. The tube on the right heater hose backdate was a bit too close to the underside of the a/c mount so I used a set of large channel lock pliers to reshape it into an oval rather than a circle. Not much of a change, but enough to give 1/8" or so extra clearance between the tube and the bracket. Also re-shaped a reinforcing piece on the underside of the a/c bracket from a 45 degree angle to a curve.
As an afterthought, I added a clamp on the ignition sensor so that I can remove and replace it without having to use a feeler gauge. The area around the sensor and toothed pulley is not very accessible so this eliminates that issue. Might not ever be a problem, but who knows?
http://forums.pelicanparts.com/uploa...1371264412.jpg
http://forums.pelicanparts.com/uploa...1371264448.jpg
http://forums.pelicanparts.com/uploa...1371264477.jpg
http://forums.pelicanparts.com/uploa...1371264497.jpg
fred cook 06-15-2013 07:37 PM
Day 45, Saturday
Spent some time this morning installing the CIS fuel system back on the engine. In order to use the CIS on the Carrera heads, a spacer is required. The top shroud had to be modified slightly at the intake runner openings to allow the spacers to drop into place. I used a spacer as a template and then made the changes with a Dremel tool. Once the CIS was back in place and some adjustments made in some of the hose clamps everything got tightened down securely. Once done, all of the electrical connections (plugs, etc.) were completed. I added the lower plug wires to the engine, running the 3 wires thru a 1" diameter hole in the side engine tin to allow them to plug in at the rear of the engine. The wires are protected by a rubber grommet inserted in the hole on each side. The upper plug wires are already attached to the DFUs and are draped over the rear fender on each side of the engine bay. Oh, yes, some parts arrived this afternoon from PP including a heater hose. I installed that hose on the right side. I thought the piece of hose would be long enough to do both the left and right, but it was not. Will order another piece of hose tomorrow. Almost done, will probably take the engine off the stand on Monday or Tuesday. Don't think I will have time to install the engine until next Saturday (maybe).
Some pictures..........
http://forums.pelicanparts.com/uploa...1371349714.jpg
http://forums.pelicanparts.com/uploa...1371349827.jpg
Before installing the engine in the chassis, I am going to double check the valve adjustments and the cam timing "just to be sure". Much easier to do with the engine on a stand than in the car!
fred cook 06-17-2013 01:47 PM
Day 46.............
Was out of town on Sunday, so nothing was done to the engine/rebuild project. So, today is officially day 46 of engine rebuild work. Was tied up before lunch, so only a couple of bits done today. I added an a/c brace to the mounting bracket. The one that runs from the front of the engine case up to the main mounting bracket. With the new backdated heat duct on the right side of the engine, it turns out that the support brace will just barely fit around the metal duct! I also made a sheet metal shield to cover the lower #3 spark plug. It took some head scratching, fancy bending careful fitting for the plug to be covered and still be available to allow the spark plug socket to access the plug. Some pictures:
http://forums.pelicanparts.com/uploa...1371501981.jpg
I would have liked a better shape/fit, but this is at least functional!
fred cook 06-18-2013 12:20 PM
Day 47
I built a lift/spreader bar for the engine so that the lifting chains won't hit or rub on anything. Tomorrow afternoon I will check the valve adjustment and cam timing (just in case!) and probably move the engine off the stand and onto the ATV jack that I use to raise and lower the drivetrain. Once the engine is off the stand, I will add the clutch and transaxle, hook up the starter and backup light wires and then it will be ready to go into the chassis!
Lapkritis 06-18-2013 01:23 PM
Geeez, that was fast. Project-a-holic and searching for the next yet? All that new shop space would have me tempted to try a couple.
fred cook 06-19-2013 03:02 AM
Good planning.......
This is a project that has been a long time coming. I started thinking about what I would do when the engine was rebuilt years ago. Then, about 5 years ago I started looking for and acquiring parts. Before the engine came out, I already had the following parts on hand: cylinders, pistons, reconditioned heads, cams, gasket set, hardware set, etc. About the only items not on hand when the engine was taken apart were the main and rod bearings, the bolts and large washers for the newer style cam shafts and a few other very minor parts that were readily available from PP or others (if necessary). Over the last month and a half, I have spent about 180 - 200 hours working on this rebuild. About 1/2 of that time was spent cleaning parts! The other thing that has taken some time is that each assembly step was done at least twice, once as a trial fit to make certain that everything was ready to go together and then the real assembly. A few items like the front engine mount from a Carrera had to be slightly modified to work with the 3.0 liter block so it was off and on several times. Also, I made some mods to the CIS (more on that later) that required more than one assembly process. Because the new engine will use an Electromotive XDi ignition system, there was some excess wiring in the engine wiring harness. Rather than just hack them off, I unwrapped the harness, removed the coil wires, the heater blower motor wires, the distributor "green" wire and the original wire that fed the external alternator regulator (the alternator now on the car has an internal regulator). Once these wires were out, I re-wrapped the wiring harness. Now, the 6 pin plug that originally went to the Bosch CDI now only has two wires left in it. One is a switched power source (to trip the ignition relays) and the other is where the tach connector will plug in. Each part of the engine or engine sub assembly has been touched, either cleaned, modified, refurbished, what ever. I even super cleaned the muffler and repainted it with some the VXT black header paint! Anyway, now, the next step is to verify the valve rocker adjustment (easy while on the stand), remove from the engine stand and install the clutch and tranny. With a bit of luck, that will be done by the weekend.
Later,
fred cook 06-19-2013 02:43 PM
Project day 48
Spent some time this afternoon going back thru the valve adjustment. Good thing that I did as I found a couple of rockers that were not adjusted properly! Both were on #6 so I may have just skipped that cylinder for some reason! Anyway, everything is "happy" now. I also added the heater hose on the left side and did a test fit of the refinished muffler. Just wanted to make certain that the muffler support bracket on the motor mount was adjusted correctly. Now, everything that I can think of is done and the engine is ready to come off the stand. Maybe tomorrow!
http://forums.pelicanparts.com/uploa...1371678091.jpg
http://forums.pelicanparts.com/uploa...1371678114.jpg
PS: The muffler will come off prior to the engine being reinstalled in the car. Seems to be easier to do that way!
iiXii 06-20-2013 08:18 AM
Nice picture
fred cook 06-20-2013 02:58 PM
Day 49
Ok, the engine is now officially off the stand! I lifted it off this afternoon using a rented engine hoist and the spreader bar that I made the other day. Worked like a charm. The spreader bar is made from a piece of square steel tubing with a piece of chain starting at the rear with a length of about 24", then bolted to the bar, a little slack left going to the front, bolted again to the front of the bar and then extended 18" to a hook. A second piece of 18" long chain is bolted to the other side of the front of the bar again, with a hook on the end. The rear chain wraps around the engine stand adapter for one lift point, and the front hooks catch on the motor mount cross bar on each side where it bolts to the motor mount console. That way the lifted engine is stabilized front to back and side to side. Anyway, the engine is now sitting on the ATV jack waiting for the clutch to be added and the transaxle to be bolted on. Will probably do those two jobs tomorrow afternoon and plan on bolting the drivetrain back in the car on Saturday morning. Latest pics.
http://forums.pelicanparts.com/uploa...1371765351.jpg
http://forums.pelicanparts.com/uploa...1371765372.jpg
http://forums.pelicanparts.com/uploa...1371765393.jpg
The piece of plywood that the engine is resting on looks to be somewhat bent. Not to worry, there is a piece of steel angle fastened under the plywood to reinforce it. I don't think it will bend much more!
soren.911 06-21-2013 12:01 PM
Very nice project.
I had to adjust my WUR on my euro 3.2 with euro carrera 3.0 CIS in order to get it run probably between 2-3000rpm. It was running too lean.
Wcp set to 2,0 bar and ccp set to 1,0 bar
fred cook 06-21-2013 06:42 PM
Project day 50
Ok, the engine and tranny are back in the chassis! I still have all of the little stuff to connect up so that might not all get done for a couple of days. In the process of putting the engine back in the car, I discovered that I had bolted the motor mount cross arm on incorrectly. So, I very carefully unfastened the 4 bolts holding it onto the motor mount console and turned it around. Other than that, the install went pretty easily. While the engine was "almost" in, I finished plugging in the plug wires going to the DFUs mounted behind the CIS system. I believe that I got everything in the right place, but will pull the CIS bonnet so that I can eyeball the wires on the right side. After making all the small connections, I will add oil, pull the top spark plugs and turn the engine over to build oil pressure. From there to running should be fairly straight forward! Will post pics of the engine back in the nest tomorrow.
fred cook 06-21-2013 06:43 PM
Thanks for the tip...........
Originally Posted by soren.911 (Post 7510072)
Very nice project.
Hints and tips like this are always appreciated!
fred cook 06-22-2013 02:58 AM
Latest picture......
One last picture before going back into the chassis! Engine with gearbox and starter installed. This is the "easy" way to add the tranny. Engine on one jack, tranny on another. Adjust up and down until everything matches up. Then, if you did a good job installing the clutch, it all just pushes together!
http://forums.pelicanparts.com/uploa...1371895096.jpg
fred cook 06-22-2013 05:31 AM
Back in the nest.......
As promised, a picture of the newly rebuilt engine back in the chassis. All of the little things have yet to be done, but it is back home now! The a/c compressor will be the last thing to go back in! Hope to have it fired up in the next couple of days!
http://forums.pelicanparts.com/uploa...1371904180.jpg
Dave Kost 06-22-2013 06:09 AM
Looking good Fred!!!
fred cook 06-22-2013 02:44 PM
Project Day 51
Ok, all of the stuff under the car is back in place! I could not remember the torque spec for the CV bolts (34 ft/lbs) so I will give them a final tweak and then REALLY be done underneath. The next step will be to make all of the connections in the engine compartment. I should be able to get all or most of that done tomorrow. If all of the checks go green when the battery is connected, then Monday will probably be startup day!
fred cook 06-23-2013 04:20 PM
Project Day 52
Today, I finished up in the engine compartment and gave everything else the once over/double check. Put 9 qts. of oil in the engine and will see if any leaks develop by morning! The car is sitting tail high (rear is up on jack stands) and it appears that I do have a small tranny leak at the shift rod seal. Once the car is back level, that will pretty much stop. I will deal with that issue the next time the drivetrain come out, a long time, I hope! I tried the clutch pedal which feels like it needs a bit more adjustment. No biggie. A couple of 15mm wrenches and that will be done also. So far, I believe that I have about 200 hours of labor in this project. Of course, that includes not only the engine building time, but mods to several subsystems as well. I'm glad that I'm not paying $100+ per hour for shop time! Once the engine is running and tuned, I will pull a vacuum on the a/c system and recharge it. I'm hoping that the larger a/c crankshaft pulley (5" dia. instead of 3 1/2" dia.) will help make the a/c a bit more efficient. The larger pulley will move the belt a bit over 15" per revolution compared to about 11" per revolution. Everyone keep your fingers crossed for the startup tomorrow!
fred cook 06-24-2013 06:09 PM
Project day 53
Went out to the shop this morning to crank the new engine only to have some issues getting oil pressure built up. I finally disconnected the inside end of the left camshaft oil line and got a pretty good bit of oil to pump out. I reconnected the oil line and let it turn over some more hoping that the oil light would go out. All I got was a bit of a flicker! I let it sit for the rest of today and will work on it some more tomorrow. I checked the continuity of the oil gauge pressure sender which was ok. Will make certain that the oil light sender wire is plugged in tomorrow. The fuel checks out ok as does the XDi ignition signal light. We'll see what tomorrow brings!
fred cook 06-26-2013 01:50 PM
Project day 55
Yep, skipped posting a day. When I cranked the engine yesterday, I got lots of oil pressure! I also got some "substantial" oil leaks. I believe they are either the oil cooler seals or the internal thermostat seals. The only way to really know and fix is to pull the engine back out. Sooooooo, this afternoon I got everything loose except the axles and the clutch linkage. I will take care of them in the morning and do the drop then. My plan is to seal off the port for the large threaded oil line (pressure line) and simply turn the S hose up so that it will hold some oil in the block. Then, spin the engine over a bit while it is on the ATV jack and see just where the oil is escaping. Make the repairs and test again. Etc. At least I am getting good at pulling and installing the drivetrain! Might come in handy some day!!!
Later,
Lapkritis 06-26-2013 02:22 PM
Can pull the oil cooler with engine in the car. Or just pull engine and leave trans alone. Just food for thought. With as fast as you work either way is fine I imagine.
fred cook 06-27-2013 06:57 PM
Day 56
Think I found the leak. I went ahead and pulled the engine and tranny back out so that I could see all the potential oil leak spots. I had made a short list of what I thought was leaking including the internal thermostat, the oil light sender, the oil cooler and the rear main seal. After getting the engine out, there was no sign of leakage on the top of the engine which eliminated the thermostat and the oil pressure sender. I used a rubber cork to seal up the pressure line that goes to the external oil cooler. To make certain that the cork did not shoot across the shop I used a battery terminal puller as a clamp to hold it all together. Added about 4 more qts. of oil and connected a battery to the starter and let it turn over a bit. No oil leak. Spin it some more, and then some more, etc. No oil leak. It appears that the leak was coming from the external pressure line (the one that I corked) rather than from somewhere else! The fitting must not have seated properly when I put it together. The good news, is that the issue appears to be identified if not fixed. The bad news is that I could have taken care of that without pulling the engine! Since I had the engine out anyway, I verified that the leads going to the various senders were correct and hot to the master plug. The connector for the oil pressure light sender fell off while I was testing it. Apparently the wire was broken inside the insulation. I put a new connector on that wire so there should not be any more problems with it for a while. I have a couple more checks to do in the morning and then the drivetrain goes back in. Maybe the third time will be a charm!
gsxrken 06-27-2013 07:51 PM
Great thread, even if I have to rotate the ipad to view many of the pics in the correct orientation. Thanks for taking the time to post; its posts like these that reassure many of us that a garage rebuild can be done... with time and patience and maybe perseverance, but it can be done.
Looking forward to a YouTube video of first drive!
fred cook 06-28-2013 02:54 AM
upside down pictures..........
The pictures that appear upside down were take on my iPhone 4S. They appear right side up on a PC but upside down on my iPhone and other related devices. Don't know why this is happening! If anyone has a solution, I'd love to hear it!!
Flat6Heaven 06-28-2013 07:43 AM
Just caught up on the past weeks' worth of work... Very impressive!
Looking forward to the startup and post run-in videos.
Fingers crossed!!!!!!
fred cook 06-28-2013 12:15 PM
This morning...........
While I had the engine out on the ATV jack I decided to do a compression check. Pulled the top spark plugs and blocked the throttle open. All 6 cylinders registered 160 psi on the compression gauge! And that is on an engine that has not run yet! The 160 should be a good number for the 10:1 compression ratio, but I was happier with the fact that all cylinders pulled the same numbers. After playing with the compression gauge, I got busy putting the engine back in the chassis and making the small connections in the engine compartment. I still have to do the small stuff under the car (clutch, throttle, axles, etc.). That should take an hour or less to finish up. Then we will see if I can make this sucker fire up!
KTL 06-28-2013 01:00 PM
Just get the engine back in there and hook up the basics to do the initial fire-up and observation/check for leaks. No need to hook up the clutch, axles if you have to take it out again. Already put yourself thru that once, don't do it again! :D
Just make sure the trans is in neutral...... So that'd be one "unnecessary" thing i'd hook up- shift rod/coupler.
fred cook 06-28-2013 04:07 PM
Some good thoughts.......
and I appreciate the feedback. However, I am certain enough that I found the problem that I went ahead and stuck it all back together. At this point in time, I can unbutton everything and drop the engine/tranny in a couple of hours! It's amazing what a little On The Job Training will do for one's abilities! I do think that I am going to buy a remote starter switch so that I can crank and watch at the same time! Probably a good $15 investment. If all goes well, it should "speak" before the weekend is out!
Lapkritis 06-28-2013 05:46 PM
I double-quadruple checked everything on mine before start up. Cranked longer than I expected while filling the carbs... the extra once-over a few times is helpful. I went over my distributor timing/firing order 3 times for example... put the rotor on #4 and Z1 after turning over once with the chain covers on and got it. Good luck - lots of fun.
fred cook 06-29-2013 06:16 PM
Day 58
Spent most of today working a Taekwondo training camp. Kind of a long tiring day, but very satisfying to see students progress!
After supper, I went out to the shop to take care of a couple of items. I had realized earlier that I had not verified that I was getting spark from the XDi ignition system. So, I pulled one of the bottom plugs (easiest to access), hooked up my remote starter switch and let it crank over a few times and short to the block. Sure enough, nice white/blue lightning bolts happened! Using the same plug, I pulled one of the top plug leads and repeated the process with the same results. Nice to know that is working properly! I've got some parts ordered from our host which won't be here for a couple of days, so I guess that I will let it "rest" until the goody box arrives! More later.
fred cook 06-30-2013 04:58 PM
It Lives!!!!
Fired it up for the first time tonight at about 5:00. While bleeding the fuel lines, I found a couple of leaks. Fixed them, mopped up the gas and hit the starter. Tried to start a couple of times and then fired right up. Opened the throttle to 2K and let it run for 20 minutes. Oil pressure light went out and the gauge was showing 3 bar(s) of pressure at 2,000 rpms. I've got video, but I believe the file is too large to post.
Lapkritis 06-30-2013 07:54 PM
Nice work.
Youtube.com is good for hosting video.
iiXii 07-01-2013 02:12 AM
Really nice post
Thanks !
Flat6Heaven 07-02-2013 07:39 AM
Great news, congratulations!
Looking forward to reading about your CIS mods' performance.
TIA,
Ben.
Kemo 07-02-2013 08:50 AM
Were you planning on getting this engine dynoed? I would be very interested in the results of that. Great build and thanks for taking the time to document all of this
fred cook 07-02-2013 01:09 PM
Dyno time.........
Yes, after some break in miles. I have a friend in the Atlanta area that has access to a chassis dyno.
fred cook 07-02-2013 01:12 PM
CIS mods..........
Just as soon as I finish up a few last items and actually get to drive this thing, I will spend some time sharing what I did with the CIS system. I need to make sure that it works before I go spilling the beans about it!
TIA,
Ben.
Flat6Heaven 07-03-2013 12:09 AM
Well, your plan was already pretty much laid out in an older "CIS" thread. You have obviously put a lot of thought into it and I can appreciate your wanting to verify actual functionality before sharing the concept.
However it may work out, kudos for following your own road. Very inspiring!
PFM 07-03-2013 06:31 AM
Fred,
Great job all around! I am sure you were smiling when you got it running. Looking forward to the CIS mods as well.
