Banned
930 engine with JE 97 mm piston ring?
Hi
I am rebuild 930 engine with JE 97 mm compress ratio 8.5, can I use Goetze (97mm-1.5 X 1.5 X 3.5mm). Need you guys input!
Thanks!
TIEN
Old 05-19-2013, 10:22 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Originally Posted by vinyl_tien View Post
Hi
Thanks!
TIEN
JE makes some pistons that are compatible with Goetze rings but not all. They offer their own product [Pro Seal I believe] that tend to be thinner.
You have to watch ring depth as well a ring width. Diameter is a given.
When in doubt call Jerry @ JE with the piston number. You can generally find it on the wrist pin boss.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 05-19-2013, 11:30 AM
Hi Henry,
Jerry retired from JE after 30+ years and his replacements do not know 911's like he did.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 05-19-2013, 11:54 AM
