I agree with Henry!!!!!!
Cleanliness IS next to godliness! I am in the process of building an engine right now and so far, about 1/2 of the time spent (5 weeks since engine drop) has been used cleaning parts. On the engine block halves, I would clean on them until I thought they were done, go back the next day and see places that needed more work. This went on until I could not find any more spots of grunge that would come off with any of the several brushes that I used nor would be affected by any of the cleaners. I don't have access to a soda or dry ice blaster which would have done a more perfect job, but with enough effort and attention to detail a good job can still be done without them.
http://forums.pelicanparts.com/uploa...1370517732.jpg http://forums.pelicanparts.com/uploa...1370517971.jpg [QUOTE=Henry Schmidt;7483152]Cleanliness is next to godliness. I like everything as clean as possible. And demand it of my product.} |
Rebuild rods $200 Rod bearings $180 ARP rod bolts $280 Case gasket set $80 Reuse mains $0 Reuse chains $0 Reuse oil pump $0 Intermediate bearings $80 Check crank $ 60 If crank has issue you dodged a bullet by finding it now. case labor ? I don't know what your time is worth Dry film lubricant on new and used bearings $90 There's nothing else in there, where is the the $5000? Oil consumption from worn rings or valve guides you can live with, a magic window from a thrown rod, not so much. Quote:
I bought an engine with a good history (known) from a totaled car, did a valve job and rings, drove it a while only to find a rod knock. My assumption was that no one drives a car with a rod knocking. Later we found out the throttle stuck on impact. The gamble is really in the history....How well do you know the history? Good luck |
It is interesting having read this and other threads that the opinion of specialists particularly is that you should pull everything apart and fully rebuild the engine if it is out. I have my engine out to replace head studs and that is all I am doing. If the bottom end fails afterwards, then I was going to anyway even if I hadn't taken the engine out! I have a little more faith than a lot of people on these threads that these engines are not actually complete rubbish, and have some chance of staying together. I keep being told what great engineering goes into them after all. I have partially rebuilt many different engines n the past without problems. I don't expect, provided correct procedures are adhered to, that this one will be any different! Maybe I am wrong and Porsche engine engineering is actually rubbish after all??
Fred, your project is looking great. Keep it up.
If you don't believe me, try to buy a good used crank for a 3.2 or 3.3. On a side note: Porsche never used the 9mm rod bolt on any 911 based race engine. Why is that? |
But that's not the point. If you are that far into a 3.2-3.6 engine it really doesn't cost that much as I illustrated earlier so that is the "time and place". If your rod does fail, you could/will be looking at a huge bill. Of course as a professional I do it right as often as budgets permit but some "while you're in there'" things are warranted not just a luxury. As a poker player I understand risk vs reward and I would rarely risk thousands on unknown rods/ bolts in a 3.2. |
Henry, you're pretty focused this early in the morning so you must be enjoying your second cup o'joe. Rod bolts won't save you from valve float. You can very well reason your way into anything with these engines. This guy titled this thread as budget so let's help him with that in mind. Your experience is finger tight rod bolts? I'd recommend an LS1 swap to escape the nightmare of inferior design. Otherwise, maybe he should just confirm torque on those instead of spending a grand minimum on a case split? Food for thought and fuel for the fires this morning. ;)
I live on a farm, so I've been up since 4:00. It's never too early to offer accurate, well established information (facts) to assist people in determining their best course of action.
Accurate information is never a bad thing when you're in the process of navigating a project, budget or not. |
Truth is sometimes the very best doesn't fit. Might be why giving advice to DIY folks when you're a professional where things must be perfect is such a task. Some of these are $10k toy cars so an additional $1k engine work on something that's working perfectly fine on a street car is hard to justify. It's a different measure than someone like you building vintage race engines that are punished and warrantied. Different methods will certainly apply. |
This whole thing is getting crazy again.
We're not talking about vintage race engines and what ifs. This is a specific engine. A 3.2 with unknown history "newly acquired" that is disassembled to the case. The weak link in this engine and all 911 engines that use 3.2 rod with 9mm bolts (not all Porsche 911 engines) is the rod design and oiling to #2 and # 5 rods. History shows unexpected catastrophic rod failures in these engines with severe financial consequences are common. As long as you [editorial you] have all the information before making your decision, you can take the risk intelligently. I'm not telling anyone to do anything because I don't have their personal information (budget, skill set, time frame, etc). What I do have are the real facts [about how these engine work, how & why they fail] and that is what I share. |
Do you case split each one of these that doesn't have ARP rod hardware? If rod failures were that bad then there should be a class action suit to get in on.
If this was a 78-83 911SC engine, I would most likely say "run it". Asking me (Supertec) what we do is irrelevant because we have a specific service. We only do complete overhauls, product development and machine work on 911 based engines. We don't do R&R, we don't tune or repair engines and we don't service cars unless they belong to me. |
I agree with Henry, its so little extra to split the case if everything is alright and if it's not you are lucky to have caught it! Its mostly time and that is "free".
I recently split my 3.6 (valve guides) and everything except the ims bearings checked out, but I didn't know that before hand. I chose to put in ARP rod bolts as well, $250 on ebay I think. |
This wouldn't hit Henry's radar as he is in the business of going down to the crank - but some DIYers also get good results with pulling the rods without splitting the case. This DIYer probably wouldn't ever do it - but it is a perfectly valid approach. Me, if I'm going to that much effort, I'm just going to split the case and, at a minimum, renew the intermediate shaft sprockets, timing chains, intermediate shaft bearings, snout bearing o-ring, etc. Measure the crank and mains, probably re-use the mains (especially considering the cost and crap quality of current bearing sets), inspect oil pump gears, DFL all bearings. Splitting the case doesn't have to be a super-costly exercise and peace of mind is priceless. On the engines I've built, they get taken to redline every time they're driven without a second thought.
Henry's point remains valid, whichever technique you use to renew the rods - specifically on a 3.2, they are a strongly recommended 'while you are in there' for an otherwise unknown engine. I have absolutely no idea why some are trying to bring valve float into the discussion when we're just trying to address a specific, known weakness in the 3.2 engine that can be mitigated while the engine is down this far. Not every thread has to be a dick measuring contest. |
I addressed the issue of replacing rods bolts and bearings without splitting the case in post # 18 but suggested that was rarely a good idea.
Rod bearing fit with respect to engine life is critical. When you measure the rod journals it is not uncommon for the journal to be egg shaped. If so, installing a new bearing on that journal is questionable. Measuring each journal through the whole and getting accurate numbers is difficult if not impossible. |
The OP has been armed with options and info at this point - may he use his budget and best judgment to arrive at a plan he (and his 3.2) can live with. |
Nobody's demanding anything. Back off.
Where can I find these fuel replacement lines from Len?
| All times are GMT -8. The time now is 04:38 AM. |
