jamesjedi's Avatar
964 W/993 (1995) Intake and My Cam - Way Above My Head!
Hi,
My 3.6 engine is the M64-01. I want to use a 993 plastic intake that I have. I have a set of cams that I am looking for an opinion on. Looking to see if there are any issues? Any help would be great.
Here are the details of the cam;
Group B Super Cup (964.246.071.2) Stock C2 964
Intake Exhaust Intake Exhaust
Lift 490 464 464 426 millimeters
Duration 240 236 236 226 degrees
Centers 111 112 112 112 degrees
Old 06-07-2013, 05:23 AM
Trophy's Avatar
THis will work with out any issue in your car, it is a pretty mild cam.
The Lobe Center angles are less than stock but is not an issue.
The lift numbers are in inches not mm. ie. 0.490" and 0.464"
Do you know if the duration numbers you have are at 1mm or 0.050"
Steven
1995 - 993 RS Tribute - 4.0l Engine plus other stuff...
2005 - Touareg V8 Tow Vehicle
Old 06-07-2013, 07:35 AM
jamesjedi's Avatar
Thanks for the reply. I do not know the duration. They were used in the 964 Porsche Super Cup series back in the early 90’s. Possibly called Group B Super Cup cams
Old 06-07-2013, 07:47 AM
Trophy's Avatar
This is the information I have on the 3.8 Supercup CAMS
Steven
Old 06-07-2013, 07:53 AM
FWIW,...Supercup cams with those 112 deg LC's do not idle below 1200 RPM nor run well until over 1800 RPM using the OEM single-throttle intake manifolds.
I'd suggest having a pair made with 114 deg LC's if you plan on using that intake system.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-07-2013, 11:23 AM
