-   -   Break in oil- first 20 minutes- Brad Penn or standard non detergent (http://forums.pelicanparts.com/911-engine-rebuilding-forum/756001-break-oil-first-20-minutes-brad-penn-standard-non-detergent.html)
Neilk 06-14-2013 12:35 PM
Hello,
Yet another engine break in question. In short, do I save my case of Brad Penn break in oil for the 20 minute initial start up or use it for the first 1K?
I hope to start my engine up this weekend or early next week. I reused the P&C and had them re-ringed, reground cam and rockers, so for the first 20 minutes, should I use some FLAPS non-detergent 30W oil and save the BP break in oil for the next 1,000 miles or should I use it for the first 20 minutes and then get a decent 30W oil? What is a decent non-detergent 30W oil that you can buy locally?
Any advice on this tiresome question would be appreciated.
Henry Schmidt 06-14-2013 01:04 PM
I understand that the Porsche world loves Brad Penn but we're seeing some of the worst results (wear) in engines that use exclusively Brad Penn. We're using Delo 400 in everything.
Neilk 06-14-2013 01:13 PM
Ahh Panic...
So I should be fine with this stuff then?
http://forums.pelicanparts.com/uploa...1371240778.jpg
Thanks for the advice!
Green993 06-14-2013 01:37 PM
And... You can get it at Costco. Although, their version is Delo 400 LE. Not sure what the LE stands for?
Henry Schmidt 06-14-2013 02:39 PM
Delo LE is for low emissions cars 2007 and later. It's all we can get in Cali.
Henry Schmidt 06-14-2013 02:40 PM
Originally Posted by Neilk (Post 7498617)
Ahh Panic...
Perfect.....
K Sykes 06-14-2013 02:58 PM
Not sure I'm tracking vs the original question. My understanding is to just use a basic 30 weight oil for the very initial run it to get rid of the assembly lube, initial metal wear and other junk from the first 20 min or so. Are you recommending the "Delo" for that, or for regular use?
Hopefully days away from heads coming back and getting on the road again..
Henry Schmidt 06-14-2013 04:23 PM
Delo, start to finish..... good to go.
Smoove1010 06-14-2013 06:26 PM
The Delo 400 LE 15W-40 that I can get at Costco is labeled as having "ISOSYN" technology and touts "synthetic performance" though it is not a synthetic oil. I couldn't help but wonder, given the conventional wisdom against using synthetic oil for break-in, if these near-synthetic properties would make it unsuitable for break-in.
I'm determined to make sure my rings seat, so (based on fear and superstition) I'm breaking in with Rotella-T before changing to the Delo 400 LE I've got in a box in my garage...
irobertson 06-14-2013 07:57 PM
Hi Henry,
Interesting observation on the engines running Brad Penn.
I was going to pick some up in a couple of weeks. Now you've got me rethinking.
The Chevron site shows a Delo Multigrade 15W-40 for use with pre-2007 engines.
Curious if this is preferable to the LE designation?
Also, would you recommend SAE 30 for the first 20 min run in period, then the multigrade after that?
I was planning on just using the multigrade from the get go.
cheers
James Brown 06-14-2013 08:19 PM
interesting, the lycoming service bulletin i just looked at says it is ok to use the same oil (like 20W50 phillips 66 aircooled engine oil) for both break in and normal use. I always used the mineral ashless dispersant oil for the first 25 hours. Now it is ok to use the same oil for that. the oil game continues.
kenikh 06-14-2013 10:42 PM
Gibbs BR.
Lapkritis 06-15-2013 05:48 AM
Cheapest oil you can get off the shelf at autozone/checker/oreilly/bond/napa/advance auto/parts plus/krager/pep boys which is normally the store brand stuff. Change after the first 30mins of operation and again at 1000 miles.
Synthetic after that at 2500-3000 miles. I've done this on a number of engines with great results. Mobile 1 or Castrol Syntec for the life of the engine. Dino oil is far more prone to caking/sludging. The brown surface stain/slime is not present inside a synthetic oil engine if you may have noticed...
JFairman 06-15-2013 12:01 PM
That's what I've done in the past too. Advance auto parts down here in Florida has their own 30 weight oil in gallon bottles for a low regular price.
I switch to the good synthetic oil after around 100 miles in a turbo though.
Nicks911 06-15-2013 12:35 PM
Sorry for the sorta hijack, Its interesting on the Brad Penn comment. I moved from Mobile one to Brad Penn and notice better oil pressure for a given engine temp. I even started a log book to make sure I wasn't convincing myself b/c its what I want to believe. Maybe Bard Penn is better than mobile one and Delo is better than Brad Penn in the order of things. I guess this should be obvious but maybe factors other than psi at a temp are more important
Henry Schmidt 06-15-2013 02:25 PM
My observations with Brad Penn have to do with excessive wear and Delo is observed to produce better numbers on the dyno.
Another observation is that air-cooled 911 engines that don't leak quite often leak when synthetic oils are substituted for petroleum oils.
Lapkritis 06-15-2013 05:03 PM
..and toilets flush counter clockwise in Australia for no apparent reason.
kenikh 06-15-2013 05:08 PM
Coriolis
CaptainCalf 06-16-2013 03:43 PM
Originally Posted by kenikh (Post 7499408)
gibbs br.
+1
Steve@Rennsport 06-16-2013 05:08 PM
Speaking only for myself, I just haven't seen ANY wear problems using B-P 20w-50 racing oil or the 15w-40 stuff.
Recently, a 3.0 race engine was disassembled after 200+ hours (thats a LOT of time for a race engine) which has been driven quite hard and everything was virtually like new: cams, rockers, bearings, etc. We simply installed new rings (old ones were still within spec), new rod bearings for insurance, and buttoned it back up. P/C's had 100K++ on them.
Two things come to mind: we are very careful about air filtering and do not use glass beading during the engine cleaning process due to the difficulty in getting every last bit of abrasive out of everything (same reasoning for never using abrasive discs for cleaning gasket surfaces).
We use soda for all parts cleaning task since it leaves a virgin surface, is water soluable, and leaves no abrasive residue.
Maybe we are just lucky, but I've been very pleased with the Brad-Penn oils for many years. Its the same basic product as the original Kendall GT-1 oil which was the gold standard since the early sixties.
