Variable Leakdown Results
I did a leakdown baseline on my recently rebuilt engine (2 k miles, new P&C, rebuilt heads).
3 cylinders were at 0%. One was at 16%. I took the valve covers off, popped the valves, spun the engine around again, always 16%. Had difficulty hearing where it was coming from. Then, rechecking again with pressure at 100 psi, suddenly the cylinder went to 0 % leakdown. 2 other cylinders exhibited this behaviour as well - 15 to 20 % leakdown, and once a certain pressure got reached (80 - 90 psi in these cases), leakdown went to 0 and stayed there on the way back down. Before I installed new P&C's, I never had this "variable leakdown reading" happen. Is this a feature of the rings on the nikasil pistons? Is this a feature of fairly new cylinder bores? Is it a feature of my very special "lucky" (cursed?) engine? Anyone else experience this? Thanks
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Air Medal or two
some freaky thing going on...you could not have a real problem then have it disappear...!
So i am guessing not serious ..Valves too tight?
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
possible that your first reading was at too low a pressure for the rings to seat.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
Air Medal or two
Now thats a good point !
![]() Thanks!
