Green993's Avatar
Chain Tensioner Question
Today I was cleaning my chain tensioners for my 993. I noticed something odd and was wondering what it means.
I pumped up the tensioner with my fingers while it was submerged in cleaning solution.
The right side tensioner seemed to build up resistance as I pumped. The left side tensioner did not build up resistance.
What is the significance of this and how do you tell if a tensioner is bad? Picture below of my tensioner:
Old 06-28-2013, 05:51 PM
Green993's Avatar
Someone suggested I retry this test with oil.
The results are that neither one of the tensioners pumps up at all. Can someone confirm that this is what's supposed to happen or are they toast.
Prior to this rebuild I had no noticeable noises at either chain box.
Frustrated!
Old 07-01-2013, 11:19 AM
sometimes it is not possible to bleed the tensioners by pumping them submerged. I know I couldn't
Try instead filling the tensioner using an old fashioned oil pump (as the one in the linked picture) and some hoses with a x-over from the hardware store
Works beautifully AND you can do it with the tensioner in place
https://www.google.no/search?q=oil+pump&rlz=1C1EODB_enNO510NO510&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=2MzRUbSgAcaz4ASbtYCABA&biw=1920&bih=967&sei=68zRUYj2E4aF4AS5qYGICg#um=1&rlz=1C1EODB_enNO510NO510&hl=en&tbm=isch&sa=1&q=oil+squirt&oq=oil+squirt&gs_l=img.3...37181.42722.0.43348.10.10.0.0.0.0.70. 534.10.10.0...0.0.0..1c.1.17.img.uxabAaj803o&bav=on.2,or.r_cp.r_qf.&bvm=bv.48572450,d.bGE&fp=f5f0ad69992b714b&biw=1920&bih=967&facrc=_&imgdii=_&imgrc=frOQwpy6WCMr6M%3A%3BQ9C4C6VAUG4P9M%3Bhttp%25 3A%252F%252Fak.buy.com%252FPI%252F0%252F500%252F22 4512209.jpg%3Bhttp%253A%252F%252Fwww.garagejournal .com%252Fforum%252Fshowthread.php%253Ft%253D169320 %3B500%3B500
80SC (ex California)
Old 07-01-2013, 11:40 AM
