PrimeMvr's Avatar
Rookie rebuild of a 3.0
I finally finished my first rebuild, or perhaps refresh is a better term. I thought I'd post this up as encouragement for anyone who is on the fence of trying it for the first time. I think i spent as much time reading Wayne's book and the wealth of knowledge here on PP, as I did actually working on it. Huge thanks to those who answered my questions and regularly share their expertise with us.
What I learned...patience...take LOTS of pictures...bag and label everything...don't skimp on tools; buy, borrow or rent the right ones for the job...put your tools back where they belong after you use them or you will waste a lot of time walking in circles looking for them...tearing down is fun, cleaning sucks, putting back together is tedious but very rewarding...don't let your over-tightening buddy put your fuel pump back in or you'll have a major fuel leak and have to wait for a new pump to arrive before the glory of the first start
My goals for this 105k mile engine were simple...stop the waterfall of oil leaks...eliminate smoking exhaust...replace any worn parts.
Here we go, she's out
Had to do it
CIS off...yuck
Look familiar?
More yuck
Broken head stud, of course.
I took this one to remind myself of where I measured the sprocket height from
This one to remind me which direction the rocker bolts were in
Speaking of the right tools...I thought I was pretty creative fashioning this large c-clamp into a valve spring compressor. After 2 valves I bought a real OHV tool. That turned aggravation into seconds per valve to remove and reinstall.
to be continued...
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 07-19-2013, 10:43 PM
PrimeMvr's Avatar
To remove the guides, I tapped the top end, inserted an M10 and they came right out with an air hammer. I believe that tip came from Henry.
Valves before and after. Permatex gasket remover and a scotchbrite do wonders on carbon.
IMS bearings were shot, mains looked great
Fast forward...crank, rods, cams, p&c all checked out...let's start putting it back together
Hardware lined up for the 574 race that everyone is paranoid about, but turns out to be no big deal.
It started getting exciting at this point
New steel lower studs all around
Starting to look like an engine
Cam timing was much easier than I thought it would be
Ta-da!
Old 07-19-2013, 10:57 PM
PrimeMvr's Avatar
Time for the moment of truth. After a few minutes to burn off the oil I primed the cylinders with, the 20 minute run in was smoke (and drama) free.
http://youtu.be/SO6ZISRvLu4
There seems to be an awfully noisy exhaust valve on the driver side. The break in oil is out and I'll readjust them before the on-road break in. Other than that, the engine ran silky smooth.
The oil filter looked good
And....drum roll please.....no leaks!!!
That's my tale. I have to finish up my CV repacking, bleed the brakes one more time after having rebuilt all four calipers, and I'll be able to get it out on the road for some more break in. Fun stuff.
Old 07-19-2013, 11:12 PM
Straight shooter
Lapkritis's Avatar
Nice work!
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 07-20-2013, 05:01 AM
NEWFIE 69 911E's Avatar
Awesome work - well done! Thanks for sharing,
Was there any damage to the heads and/or cylinders from broken lower studs? If so, how did you deal with it? Thanks,
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 07-20-2013, 05:32 AM
PrimeMvr's Avatar
Fortunately there were only two broken studs and they were not on the same cylinder. The mating surfaces showed no signs of damage.
Old 07-20-2013, 09:49 AM
Smoove1010
Smoove1010's Avatar
Nice work - congrats! Nothing like that first startup...
GK
Old 07-20-2013, 09:58 AM
Goodgame man ! Do you powder coated you fan ?
Old 07-20-2013, 11:08 AM
PrimeMvr's Avatar
I did not powder coat. I used a high temp auto enamel. Powder coating is certainly more durable, but it looks good for now.
Old 07-23-2013, 07:35 PM
irobertson's Avatar
Nice job.
Great to see/hear it running again, and leak free too!!
Way to go.
'88 sunroof delete Coupe in Venetian Blue (back on the road Wooo!)
'11 Cayenne Manual, as in it has a clutch :-) (daily driver)
'97 BMW Z3 (wife's ride)
Old 07-24-2013, 08:57 PM
