Aircooled Camshaft Nut Tools P202 and P203
I have a thread which is all about the rebuild of my 1978 911SC engine. I have got completely stuck however because I cannot source the 46mm crowfoot tool and associated camshaft holding socket, part numbers P203 and P202. Even Porsche don't supply them any more it seems.
My question is what do I do, or more to the point, what does everyone else do to get these things apart?
Is there a UK supplier who has these tools at a reasonable price maybe?
Old 07-29-2013, 01:53 PM
docrodg's Avatar
They are available here at PP
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 07-29-2013, 02:27 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Pelican also sells Stomski tools and they created a nice alternative to the separate crowsfoot and cam snout bar. Pretty slick tool.
911 Cam Nut Tool
Kevin L
'86 Carrera "Larry"
Old 07-30-2013, 12:25 PM
Smart quod bastardus
fredmeister's Avatar
Getting them apart you can use an impact gun and a 46mm socket.
You may want to consider getting the ends of the cams machined to the later style 83SC bolt and washer setup and use the later tools to assemble it. This eliminates the huge crows foot and special socket tooling. you will still need the later cam sprocket tool but this might be easier to source.
Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-30-2013, 12:56 PM
