-   -   Case Through O-Ring trouble?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/764285-case-through-o-ring-trouble.html)
Lapkritis 08-07-2013 09:18 PM
Originally Posted by johnman001 (Post 7590397)
Which flavor? I use Krytox 226 on bearings. It is expensive $150+ for a cartridge, but it does work well in certain applications. It is Fluorinated grease.
It is good for around 500°F, but I prefer o-ring grease for o-rings.
I believe in using whatever works for you.
GPL 207 is the preferred flavor. I also use this on the oil return tube, distributor, oil cooler and other rubber ring seals. There are many forms of Krytox out there with various properties... this one is suitable.
Mr Project 08-08-2013 10:06 AM
Timely thread for me. I haven't really started assembly yet on my '84 3.2l but I checked the case last night and I only have chamfers on one half of the case as well. I ordered the tool from McMasterCarr and will take care of that before I assemble.
Henry Schmidt 08-08-2013 10:54 AM
We use the Dow 55 for two main reasons.
First, the Dow is a Phenyl-methyl silicone grease formulated for O-rings with properties that add a slight seal swell for increased sealing of rubber (including synthetic rubbers) to metal surfaces.
Second, silicone based products like Dow 55 resists the capillary action or wicking that can occur when white grease is used to seal petroleum based oil products.
Lapkritis 08-08-2013 11:42 AM
Henry,
Are you using this Dow Corning 55 Molykote?
http://www.dowcorning.com/applications/search/default.aspx?R=392EN
I know they have different flavors but see this carries a relatively low temp rating. Would like to compare to the Krytox specs.
KTL 08-08-2013 11:45 AM
Dow 55 in a 5.3 oz. tube is on sale at Grainger for $6 on clearance. And then newgrainger.com opens and it's gone.............
Henry Schmidt 08-08-2013 03:26 PM
Originally Posted by Lapkritis (Post 7591394)
Henry,
MOLYKOTEŽ 55 O-RING GREASE
No, we aren't using commercially available Dow 55 Molycote. We're using a mil spec product directly from military suppliers.
As to your question: what specs do you believe Krytox has that are important to this application? I'm wondering what function you think a lubricant in this application (o-ring that seal engine oil) performs?
That question was awkward so put another way: why are we (engine builders) putting anything on an o-ring?
Lapkritis 08-08-2013 04:20 PM
I was going to put the spec sheets side by side. Not commercially available you say but yet you sell it making it... commercially available. Is that right?
johnman001 08-08-2013 04:41 PM
My answer to "why are we (engine builders) putting anything on an o-ring?" is:
To keep the o-ring from becoming compromised during installation. This would include ripping, tearing, or pinching the o-ring when assembling the parts. The lubricant allows the o-ring to move instead of stick on the surgically clean dry surfaces that we have prepared prior to assembly. Without lube, it would be all too easy to damage the o-rings and prevent them from functioning in their intended purpose (to seal oil in and dirt out).
just my $0.02 (like I said before, use what works best for you. The opinions here are just that, opinions, and your mileage may vary.)
Henry Schmidt 08-08-2013 05:42 PM
Why so combative?
The truth is, I don't sell it. I buy it in large quantity container that makes selling it impracticable. Much like most of the products I make, I made them because I needed them for my projects.
I needed a high quality o-ring lubricant so I sourced the best I could find for the shop. It works well so a add a small amount (literally a little baggie) to my sealing kit as a favor.
Johnman: You are absolutely correct "To keep the o-ring from becoming compromised during installation". After the o-ring has seated, the lubricant has done it's job and any product that can cause a capillary action or wicking is counter productive. That is why we avoid white grease and petroleum products in these applications.
Lapkritis 08-08-2013 06:13 PM
I'm not combative, but I would like to compare the materials by the data sheets. Why aren't you forthcoming? Just curious.
safe 08-09-2013 03:33 AM
I used Dow Corning Molycote 111 (because it was the o-ring grease I had) on my ongoing rebuild for the o-rings. That wasn't a mistake I hope?
Henry Schmidt 08-09-2013 06:48 AM
No worries Magnus, Dow 111 is primarily a Silicone-based compound that resists wicking and has been used by many people on this forum with success.
safe 08-09-2013 07:34 AM
Thanks, good to hear!
They did go in quite smooth.
Aurel 08-09-2013 03:37 PM
I used the sealing kit from Henry with the green viton O-rings and the Dow 55. Unfortunately I had the through bolts on the wrong side, and decided to reinstall them on the oher side, for purely cosmetic reasons. Some got damaged in the process, and I can see one that did excatly what the OP shows in the picture.
Now I still have the blue O-rings that came with the case sealing kit. Can I use those with the Dow 55 or are they going to be worse than the green ones?
The issue is the same with my SC case: the bores are not chamfered. So does this mean that the blue rings are similar to OEM (harder?) and will work better in my case?
Henry Schmidt 08-09-2013 03:44 PM
The blue o-rings were designed for a different sealing/washer system. They are very soft and under similar conditions will show even more damage (less chance for good sealing) than Viton o-rings. You're always taking a chance if the case holes are not properly chamfered.
lindy 911 08-09-2013 04:34 PM
Or you could just lather on some more lube, that ought to do it.
lindy 911 08-09-2013 05:01 PM
;)http://forums.pelicanparts.com/uploa...1376092374.jpghttp://forums.pelicanparts.com/uploa...1376092445.jpghttp://forums.pelicanparts.com/uploa...1376092550.jpg
Just thought our O-ring guru would like to see what a properly cleaned engine looks like before reassembly...
Lapkritis 08-09-2013 06:11 PM
Metal masturbation.
Lapkritis 08-09-2013 06:40 PM
So the Dow 55 Silicone grease:
1) Weakens rubber tensile strength tremendously.
2) Causes rubber to swell greater than 10%; Viton actually will shrink. Common application is for temporary relief of gearbox leaks.
Keep slapping it on there though. I sure as heck wouldn't.
See for yourselves:
http://www.cibsupply.com/pdf/dc55.pdf
irobertson 08-09-2013 06:51 PM
Henry, would you have a nice pic of a "properly chamfered" case hole?
