cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
colder plugs for higher compression
With new JE pistons I think the compression is going to be 9.8 / 1. I am concerned about detonation with a single plug and super unleaded gas. I ordered the following plugs
NGK Iridium BR9EIX
I think stock heat range is 7 for street 8 for track 9 for me.
Anyone see a mistake with my choice?
Chris
73 911 E with DC 30 cam
Old 08-12-2013, 11:51 AM
rsscotty's Avatar
That is what we use. You are making the correct choice.
Old 08-12-2013, 12:55 PM
cmcfaul's Avatar
Perfect
Many Thanks
One more thing to check off on the internal list of good decisions.
Chris
73 911 E
Old 08-12-2013, 01:10 PM
Speed Dog's Chauffeur
Dodge Man's Avatar
Copper Core?
Your heat range is spot on for non-extended MFI plugs. I went the route of NGK Copper Core plugs which were less $$. NGK also has the radio resistor BR9ES if you want old fashioned copper core to test. I got some copper core plugs off Amazon for $2+ each for my stock 9.8 CR CIS 930/10 and it is happy. I even have some Bosch W3 & W4 MFI plugs in the garage if you want some test/tuning pieces. Best of luck
Old 08-13-2013, 01:06 PM
