-   -   alternator or Voltage Regulator (http://forums.pelicanparts.com/911-engine-rebuilding-forum/766568-alternator-voltage-regulator.html)
cmcfaul 08-17-2013 06:36 PM
My car, fresh from complete rebuild, is a screamer:-) Only problem is it's not producing enough voltage. I had the alternator rebuilt a while ago and replaced the voltage regulator at the same time.
So, how do I tell if its an alternator problem or voltage regulator problem? The voltage regulator is separate from the alternator.
Thanks in advance,
Chris
73 911 E
PorscheAmateur 08-18-2013 02:12 PM
Easy way to tell is to go to battery with a multimeter and get these results:
Car Off Batter Volts: (should be 12.something
Car Running with RPM at 3000+: should be above 12 and at least 13
Car Off again: should be 12. something.
If when the car is running you don't get anything different or above 13, then you probably have a bad alternator. If the car reads like 16 or 17 when running, the voltage regulator is broken and need replaced. Hope this helps. And if you need the alternator rebuilt, I used Central Jersey Starter and Alternator in NJ
