throttle bobys
Hi
what is the best way/option to go if i want to put individual throttle body's on my 911sc? |
Search the forum ( itb) there are plenty to choose from.
Good luck |
"throttle bobys"
Are they the English version? Lots of Options out there: PMO Jenvey Hargett Precision Other that make kits using mainly Jenvey ITB's" Rothsport 9M |
HeHe!
sorry i ment ''throttle body'' will have a look at above mentioned options and give an update |
throttle bodys aint cheap! but so nice
Rothsport make a great setup that is designed for the 911 spec series which I believe is based on SC engines. The only problem they are very expensive and of course you also need an aftermarket ECU to make it all work.
2001 (or so) Suzuki GSX-R750 individual units. Set of 4 for $100. So need to buy 2 sets. 42mm inner diameter at throttle plate. Takes a bit of effort to convert but they are very cheap, very light, and very effective.
Will have a look at Rothsport and see what direction to go! I have a nice aftermarket ECU system,
So I am 1 step closer |
Will also check out the GSXR ones out! Will give an update if I find something
Triumph Triple itb's ;) ...less wastage, lol
I find the perfect throttle body package! And it includes the ECU system and easy to install!
Will update with pic when I received it,TROPHY you will like it |
Dzug???
Do Tell....
Almost done!
That looks great, who makes it?
Yeah, come on- tell us something good! :)
Will give all detail on everything soon,just want to fit filters and dyno
We have used Jenvey and PMO.
Jenvey have a straight intake manifold, PMO uses a Weber style intake. Jenvey a pain to balance, PMO easy as pie. Jenvey requires some adaptation as they were designed for a cable throttle, but it is easy to configure a rod set up or spend $$$$ on the Rothsport linkage. We seem to make more power with the Jenveys... PMO have the classic weber look.... I have another set at the shop I will post pics of because I can't tell who made them. They are interesting but have a rather oddball linkage set up that will need some work. We plan to use them on a 2.8.... Cheers |
Boy would I like to throttle these boobies.:D
http://forums.pelicanparts.com/uploa...1377654205.jpg Sorry... I just couldn't resist. |
| All times are GMT -8. The time now is 07:13 PM. |
