-   -   Twin plug heads (http://forums.pelicanparts.com/911-engine-rebuilding-forum/769369-twin-plug-heads.html)
wp935 09-03-2013 05:21 PM
Twin plug heads
What is a realistic $$$ number to convert a set of 2.4 heads to twin plug.
Thanks,
Woody
afterburn 549 09-04-2013 03:35 AM
Define who is doing bthe work
You?
or just parts?
pulling the heads and having holes drilled is the cheap part.
Now you have a 1000 ways to go.......no EZ answer
MBruns 09-04-2013 06:20 AM
Twin plug
If the heads are clean and disassembled we get 500.00 to twin plug includung the valve cover machine work, your choice in 12mm or 14mm
Mike Bruns JBRacing.com
JmuRiz 09-04-2013 07:48 AM
Are different fixtures needed for a 2.4/2.7 than for a 3.0 head? I know someone that has the fixture setup for a 3.0, but not sure if it would work on my 2.7.
cgarr 09-09-2013 04:53 PM
yes
JmuRiz 09-10-2013 06:31 AM
Bummer, thanks for the info though.
