Twin plug heads
What is a realistic $$$ number to convert a set of 2.4 heads to twin plug.
Thanks, Woody |
Air Medal or two
Define who is doing bthe work
You? or just parts? pulling the heads and having holes drilled is the cheap part. Now you have a 1000 ways to go.......no EZ answer
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Twin plug
If the heads are clean and disassembled we get 500.00 to twin plug includung the valve cover machine work, your choice in 12mm or 14mm
Mike Bruns JBRacing.com
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Are different fixtures needed for a 2.4/2.7 than for a 3.0 head? I know someone that has the fixture setup for a 3.0, but not sure if it would work on my 2.7.
'73 2.0 914 (2.8 /6 conversion in progress) '64 356SC '65 Ducati Falcon 80 ‘19 Audi SQ5 |
abit off center
yes
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Bummer, thanks for the info though.
