Would SC cams get more HP in 930 motor ?
Thinking about installing SC cams in a turbo 930 (1979) motor. Will there be a increase in horsepower?
Old 10-02-2013, 05:50 AM
Try not, Do or Do not
Henry Schmidt's Avatar
We have built many turbo engines (15-20?) over the years using SC cams and I love them. If you're build a high tech EFI engine you can probably find a better / more modern profile but with the stock CIS injection the SC cams hit hard and still idle and transition nicely.
I would probably recommend the K27-11 turbo to match.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-02-2013, 06:37 AM
