Wrist/piston/Gudgeon pin Circlips
I was always advised not to reuse the circlips that hold the piston pin in place as they can fail. I did have this happen on a motorcycle and you can imagine the damage. Nowhere in any book, however, does it comment on the circlips as parts to keep, replace or anything. They seem to be absent from most UK parts suppliers stock lists even though pistons and barrels are readily available. Does anyone have an opinion?
Old 10-14-2013, 02:09 PM
Measure the groove for the circlip in the piston, im sure you can find a set in the correct dimension from other pistons with the same size pins as std component like a circlip is more the likely reused on lots of different pistons.
Old 10-14-2013, 02:55 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Factory manuals say not to reuse them. They're less than a dollar a piece. I just bought 12 of them ($0.42 each) for a set of used low mileage Carrera pistons I have that I plan to sell. $5 is very cheap insurance.
Here's teh 993 manual for reference
Kevin L
'86 Carrera "Larry"
Old 10-15-2013, 06:55 AM
Thanks for that. I was planning to replace them anyway. Interesting however that no other engine rebuild books seem to mention this!
Old 10-15-2013, 11:03 PM
This is the first time I've heard of this. I'm sure it's a good idea to replace them, however, they don't seem to wear out and I've never seen one break.
-Andy
Old 10-18-2013, 09:54 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
For sure, do replace them. They certainly don't wear out but the act of removing them can deform their shape and possibly mean a less than perfect fit in the groove (if re-used). I can tell you from my motorcycle rebuilding days, a popped out circlip does awful mean things to a cylinder wall.
Old 10-22-2013, 10:33 AM
-Andy
I've seen several broken ones so its always good practice to replace them.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-22-2013, 11:08 AM
